oL is an Overload error. Try running a cycle empty.
If oL (overloaded) appears in display, the load too large. If an overload is detected, the washer will drain any water and detergent in the washer. Remove several items and add HE detergent. Close lid and press START/PAUSE.
An F/dL error code indicates a problem with the door lock. The error code will pop up when the door fails to lock. The washer will display the error code after six attempts to lock the door. To fix the issue, the door lock assembly needs to be inspected for loose or broken wires and other signs of damage.Oct. 4, 2021
Press the Pause or Cancel button twice and the Power button once to clear the code. That code is a speed sensing fault. Maybe the washer was overloaded?
The Cabrio Washer F2 error happens when the main control detects a stuck key on the user interface. The steps to take to try and fix the F2 code problem are below:
Unplug the washer for five minutes and then plug it back in, this will reset the control board. If the persists then the only way to fix it is to replace the user interface board.
Sep 11, 2005 - 10 posts - 5 authors
My washing machine stopped after filling and won't wash, drain or spin. ... and then come up with either LD, FL Or SL code and stop working.
? 2:59
https://www.youtube.com/watch?v=tFBtD2wUj4g
Jun 21, 2009 - Uploaded by liquid131
Whirl Pool Cabrio LD Temp fix pt.2. animal131 ... How to override an error code on the Whirlpool Cabrio washer - Duration: 3:08. Whirlpool ...
It is overload error.
"oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill •
and begin the wash cycle. If the washer is overloaded, it will
drain any water and detergent that was added during the fill.
To correct the overload, remove several items and add
detergent. Close lid and press START.
Also try to download user manual from this site and check page 19.
Hi Thanks
for using FixYa. Error oL means overloaded and it flashes
when the machine/motor control detects a load size that exceeds the washer’s
capacity. To clear this error you’ll have to open the door lid to clear
display, remove excess laundry, then restart the cycle. Please
do rate the solution if the issue is resolved or post a comment for further
assistance. Thanks Rylee
Thanks for using FixYa. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
