SOURCE: noisy water heater blower
There really is no way to do this. If you put a cap you will restrict the air flow which will cause you to have problems with the water heater, same thing if you where to put screen on it. You can try enlarging the pipe to a 3 inch and see if that works. But 15 years in the trade nothing has been made to reduce the noise
SOURCE: I need an upper element for my Bradford White
Go to your local hardware store, i perfer lowes or ferguson's
SOURCE: Bradford White LP water Heater Power vent ,flame keeps going out
flue is overheating make sure outlet is not obstructed outside and if not that you feel a good air flow coming from it
SOURCE: I have an electric Bradford white water heater
You need to check the electric elements they are under removable covers on the front of the heater and check the fuse/breaker. May need to replace upper and lower elelments
SOURCE: reset button triping on bradford white electric
replace upper thermostat, and hi temp limit, usually made in one piece, also make sure the new stat is pushed up tight to the tank when you install it.
