User manuel installation
Try using Google to find the manual. That is manual with two a's, not manuel, a Spanish proper name. I am sure you can find what you need by web search or going to the Hunter website.
Manuals Lib has the manual for the Hunter Set & Save 47300A here: https://www.manualslib.com/manual/73833/Hunter-Set-And-Save-47300a.html . This includes the installation instructions and the instructions for using the thermostat. You can download the file by pressing the Download button near the top of the page. There will be a prove you are not a robot challenge before you can get the PDF.
I hope this helps.
SOURCE: Hunter 44100A programmable thermostat
Sorry Iasumed you had a heat pump t-stat. You will need to exchange to a heat pump t-stat
SOURCE: thermostat won't stay on, even with new batteries on hunter therm
replace the thermoste with a new one its easy to do
1.turn of breaker to doorbell air handler and compresser (outsideunit)
2 take of thermostat lble wires as to wich leters they conect to
3 put on new thermostat enshuring whires are conected to corect letter
4 turn on beakers and enjoy!!
SOURCE: Trouble Installing Hunter Brand Thermostat
on the back of the packaging for the HUNTER MODEL 44155C it states that it is not compatible with heat pumps
SOURCE: Bought 44155c hunter thermostat air won't turn on.
If unit worked before you tryed changing t-stat then its possible the t-stat wires are shorting each other out.take t-stat back off cut back wires a good 6 to 10 inches or if you dont have that much wire to play with just cut back as far as you can and make sure there is no bare wire touching each other ,then just to test unit to make sure its working ok twist yell.,red,green together this should bring both units on and should blow cold.if this works up to this point on the new stat read directions closely there might be a jumper wire in the stat that needs connected usually from y1 to w1 you would install a jumper wire .see if this helps if not write back i have 1 other solution.i hope this helps
