I've managed to remove the cds but now the cd changer won't work and it makes a strange noise when powered up. What part is likely to be broken?
SOURCE: CD Changer
You can probably fix it yourself but you may need some parts. Here's Denon's link that'll take you to the next step http://www.usa.denon.com/
SOURCE: technics 5 cd changer sl-pd787
Does it show the disc length or any other details? Have you carefully cleaned the lense with a q-tip and some alcohol? Can you hear the laser moving in and out of focus? If you push the laser sled out away from the centre does it move back to the middle when youi put a disc in?
SOURCE: Technics 5 cd changer Model sl-pc11 will pick up
System will not play Mp3 or data format cds.
Audio cds only . Also Clean lenses with a cd lenses cleaner .
clean cd also straight away from center ,soft cloth
Check for scratches .
SOURCE: Looking for a drive belt
A rubber "O" Ring as a belt solved the problem. At our local hardware store: 1 1/16 OD x 15/16 ID - 1/16" wall $0.39!
SOURCE: Cd player in 2003 Jeep Liberty will not play or eject cds.
you might want to just take the factory cd player out and put a after market one in cause thats what i had to do on mine casue it costs way to much to get the original one replaced
