SOURCE: artista 180 driner
hi you need to get the right software for artista 180.I have just sold
my 180 and i still have the software on my computer. You need
the software called CPS 4.1...EMAIL me at [email protected] i might be able to get a copy off my computer for you
Lawrence
SOURCE: can I transfer a pattern from brother 4000d machine to usb
Welcome to Fix Ya!
Are you trying to transfer a built-in pattern from your machine to a USB flash drive? I'm not sure if built-in designs can be transferred in their original form. You might try editing the design a bit, save it to a memory space, then save it to the memory stick. If you have a manual, it should describe how to move designs from your embroidery machine to your computer, and vice versa.
If you are other readers have time to rate my answer, you'll help me become a better expert. If you can give me more specific information about what happens when you try to upload a design from your machine, and whether you have a manual feel free to leave a comment and I'll check back with you.
Cheers, Ginny
Ch
SOURCE: Marie Osmond emotions embroidery machine...how do i delete saved?
Check the tension. Bobbin tension. You need to use only Isacord thread. The cheap stuff will get caught and break the needle everytime.
YES you can delete designs. When the screen is up that is showing you what it is stitching. Click on grey box that pulls up everything you have ever stitched and click on one and then select delete.
SOURCE: Baby Lock Embroidery Sewing Machine
I had the same problem and after buying a new card, found out that you get that message if the pattern you are trying to transfer is too big. reduce the size of the pattern and see if that works
SOURCE: 4D d-card reader/writer - seems to be installed but not working
I have been having the same problem. I was told that the 4-d software is not compatible with Windows 7.
