Tech Support from this link: http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Technical Support (Simplex, E-Plex, PowerLever, 4000 Series, Solitaire 850L, Solitaire 850/950)
1-800-849-8324 (option 3, and then option 6) Tech Support is probably your best bet!
use the other side of the spanner wrench with the point and insert it into the hole in the inside sleeve and you will feel some spring tension.........push in the tool and pull the handle off at the same time.
If the handle has been forced their is a part inside that is broken and it appears as if the handle is loose. I have priced the replacement parts and they were over 75% of what I could purchase the whole thing for ,so I elected to purchase new and go with the direct replacment model L1000 (Lever) to make it ADA compliant at the same time.
