SOURCE: After 27 minutes into wash get an FH error
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter is sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
If you're really in a hurry, can not find a solution, you can ask the customer service hotline, the time to buy some warranty phone, you can call to ask, maybe there will be resolved.
