First you will need to connect it to an appropriate scan tool that will give you the codes that have turned on the check engine light and that will guide you in the correct direction to repairing your Hino.
I ask you sir how many source of check engine can cause check engine because I'm here in province and I have no gadget to get the codes if you know please tell me what is what is the sources of that I manually check than one by one
Honestly it could be a 100 different things. Have you tried draining the water from the water separator?
You need to get the OBD codes read, this will identify the code for the faulty sensor/component
SOURCE: hino truck k13c if i start the engine automatically shotdown,after the engine didnot start already.
Is this a diesel motor? If its a diesel bad glo plugs.
