Https://support.hp.com/us-en/product/HP-LaserJet-Pro-CM1415-Color-Multifunction-Printer-series/4089171/model/4089467
Testimonial: "Thanks Stephen. No luck with that."
go to their Online center here's the link:https://support.hp.com/us-en/product/HP-...
SOURCE: Error 59.99 Printer Error
An error occurred in the secondary transfer
engaging mechanism.
1. Faulty secondary transfer engagement
sensor. Replace the secondary transfer
engagement sensor.
2. Faulty secondary transfer engaging
solenoid. Replace the secondary transfer
engaging solenoid.
3. Faulty feed motor. Replace the feed
motor.
4. Faulty DC controller PCB
Action: Replace the DC controller PCB.
SOURCE: Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
SOURCE: ''Page too complex'' message on HP color laserjet 2840 Multifunct.
On the printer, hit the menu button
Then navigate using your left arrow button until you see Main Menu - Service, then hit enter
then use the right arrow to navigate to high speed usb and hit enter.
it should now show on, use the right arrow once to change it to off and hit enter 2 times
let the printer reboot and its should be fixed
SOURCE: Error 58.04
This is from the service manual and should help you
determine if you need to call in for service. If is in warranty I would
anyways since the fuser would be covered if at fault.
58.04 ERROR To continue turn off then on. The low-voltage power supply has experienced an error.
1. Reinstall the fuser. Check the connector
(J1901) between the fuser and product.
Replace the cable or fixing unit if the
connector is damaged.
2. Reconnect the connectors of the fuser
control PCA (J303, J305) and the DC
controller PCA (J107).
3. Replace the fuser. See Fuser
on page 191.
SOURCE: hp color laserjet 3550 59.99 printer error
This error shows
An error occurred in the secondary transfer engaging mechanism.
1. Faulty secondary transfer engagement sensor.
Action: Replace the secondary transfer engagement sensor.
2. Faulty secondary transfer engaging solenoid.
Action: Replace the secondary transfer engaging solenoid.
Action: Replace the feed motor.
