There could be a few different reasons why your Kingavon mobile calor gas heater is not producing heat despite igniting. Here are some potential causes to check:
Burner or pilot light: Check to make sure the burner and/or pilot light are not blocked by debris or dust. Use a soft brush or compressed air to clean them off.
Gas supply: Make sure the gas supply is turned on and there is adequate gas pressure. Check to see if the regulator is working properly.
Thermocouple: The thermocouple is a safety device that shuts off the gas supply if the pilot light goes out. If it is malfunctioning, it may be preventing the gas from flowing properly. Try cleaning or replacing the thermocouple.
Gas valve: The gas valve controls the flow of gas to the burner. If it is faulty, it may not be allowing enough gas to flow through to produce heat. Try cleaning or replacing the gas valve.
Ignition system: If the ignition system is not working properly, the gas may ignite but not produce enough heat. Check to see if the spark electrode and ignition module are working properly.
If none of these solutions fix the problem, it may be best to contact a professional repair technician to diagnose and fix the issue.
My kingavon calor gas heater has a new 15k gas bottle. The heater is just over a year old. I can ignite it but the blue flame is small and won't light the burner thing
Hi there.
Check for wiring errors, fix and tighten all wiring connections. Make sure that the gas pressure is correct.
Check the hi limit and gas valve, one of those component may be bad.
Regards.
yes they do go bad some times they have a hairline crack in them and the will spark but never light the gas they have drove me nuts many a time , for no reason they will not light , then replaced it and wham it works .
gas fire in house and pilot will not stay alight then its the bi-metal thing in the flame needs renewing ,its brass and ivor metal and it expands to hold the valve open ,now can i please answer the car questions ?
