Pool & Spa Logo
Frankie Finck Posted on Jan 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Heater on an index bubble spa isn't working. The head says it is 112. It worked fine yesterday but not today. Did heater to bad? Also get a code E96
William Bailey
Level 2:
Sergeant:
  • Expert 171 Answers
  • Posted on Jan 18, 2019
William Bailey
Expert
Level 2:
Sergeant:
Answers
171
Questions
0
Helped
48757
Points
502
Try unplugging it to see if it'll reset if it does not take off the back panel and loosen the B and C connector and let water starts to drip out a little reconnect them plug it back in that should clear it up.
Steve Cox
Level 3:
Master:
  • Master 674 Answers
Steve Cox
Master
Level 3:
Master:
Answers
674
Questions
0
Helped
213293
Points
1718
Check the manufacturer for the code. That will tell you what the malfunction is.
5 Related Answers
Anonymous
  • 625 Answers
  • Posted on Oct 15, 2007
SOURCE: heater will not operate!
did you take it apart to see if the switch is good or the thermostat was functioning?  without looking inside, other than saying it don't work, isn't going to solve anything.
Anonymous
  • Posted on Jun 13, 2009
SOURCE: Hayward H300 Spa Heater will not fire up
try to replace the thermo sensor it is located on the left side of tghe unit and has 3 wires running to it.
Anonymous
  • 3 Answers
  • Posted on Aug 02, 2009
SOURCE: layz spa pump
same problem I had so I seperated the globe by taking out the 5 screws around the middle then removed the nut from the hole the filter sits on its a strange fitting and must have a special key but I improvised by tapping it anticlockwise using a screwdriver and rubber mallet, once open identify the heater unit (it has a single wire going into it and is fastened to a length of metal pipe) and remove it by loosening the clamps at either side and pull the heater free, once free dismantle the plastic casing on the top of the heater inside you will see the live, neutral and earth wires, you can see the live (brown) wire goes to the water flow switch then the temp switch then the heater all I did was bypass the water flow switch by disconnecting the short wire from it going to the heat sensor and replacing it with the brown wire coming from the mains and it works fine now
Anonymous
  • 760 Answers
  • Posted on Jul 05, 2010
SOURCE: rheem digital gas pool heater fan code
The Fan code would indicate a problem with the combustion air blower. The is a pressure switch to indicate there is sufficent combustion air, and if not then unit shuts down. Either the fan isn't running, or there is an obsturction in the fan or exhaust piping, preventing enough air flow.
cfh would be call for heat, which would be a normal display when water temp is below setpoint
See the link below for a manual. Once you open the page look on lower right side for documents, then install manual
http://www.rheem.com/product.aspx?id=2388EEB7-3DEC-4601-AE76-EC7A07F17630
Mike Tellegen
  • 1631 Answers
  • Posted on Apr 11, 2015
SOURCE: Please help I have a intex pure spa and it has
According to Intex - E96 is a "System Error", and the most common problem associated with that fault code is a failed GFCI Cord End.
Look here for replacement;
Leviton 16693 15 Amp 120 Volt Grounded Compact Automatic Reset Right Angle...
My "Millennium" spa has stopped circulating. The heater turns on but soon turns off within a minute or so. What should I look for to fix the problem??
I would start at the termostat,you could check water temp with cooking thermometer.let me know what you find out.
Nov 29, 2013 • Pool & Spa
1helpful
Rheem digital gas pool heater fan code
2answers
Heater won't go on my jucuzzi model 315
upper spa side control should have a heat lite, if on then heater is recieving voltage. Sometimes pump can have an air bubble in line.
Make sure water is flowing from jet. Spa will not lite heater without water flow. If no water try loosing union after pump to pull air through, so pump can fill with water, and no longer cavitate. Kirk
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
