I want to know the number of shutter clicks of a Panasonic TZ3 compact camera. How can I do this?
SOURCE: Panasonic TZ1 flash problems!!
Panasonic knows about this and can fix it. It involves replacing a circuit board. I sent them my camera (Elk Grove Village, IL repair facility) at the beginning of Dec with a letter giving six web sites reporting the problem and asking them to fix it free of charge. I don't think the camera was on warranty, but I received it back, fixed, and with no charge, in about a week. Panasonic really came through on this and there is clearly no fix other than this one... except to stop trying to take flash pictures.
SOURCE: Error message (turn camera off
hello, had same problem. did put camera in play back mode, and in the menu did reset everything.
Jack
SOURCE: camera wont turn on
First thing is to be sure battery and its connection to camera terminals is good. Be sure the battery charges normally when plugged into its charger. Charger light should be green when charging, then go out when done.
Next is to clean the battery contacts with a clean pencil erasure to remove any potential contamination built up. Now, try to measure the battery charge across its pos (+) and neg (-) terminals. This means either finding someone who can do this for you if you don't have a Volt Meter, or buying one at RadioShack or any Auto Parts store. The simple ones are cheap and this is all you need. A fully charged battery should measure about 4V DC.
If the charger and battery are good, then with the battery out of the camera, cycle the camera power switch on/off several times to try to clean its contacts. Now install the battery and move the power switch to on and hold for a good 5 seconds. Repeat this a few times.
If no response, then camera is defective. Sell it on ebay auction to a repairman who will buy it to fix and resale. Now buy youself a used, refurb w/warranty, or new on on ebay. Prices are very good because many are for sale(this is a very popular camera and millions were sold) and the TZ3 has been replaced with the newer TZ5.
It is easy to post your camera on ebay. Just search for a TZ3 for sale and on its Ad Page, you will find a link that says "Sell one like this". This will set you up with a TZ3 Ad Template w/default picture and Specs, and you just follow the prompts for your Headline/price/shipping/ etc.
SOURCE: Repair of Camera digital Panasonic DMC TZ3
Not sure whether you'd call it a solution, but I took my battery out then put it back a couple of times and the camera started working normally again!
SOURCE: memory card locked panasonic lumix dmx tz3
Sounds like the card might be either badly fragmented or damaged. I would suggest formatting the card in camera-this should fix it.
Hope this helps,
Raf
