SOURCE: problem with sharp AR-5320 photocopy
cek the heater unit, usually the heater lamp is off, or thermostat cutoff
SOURCE: add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
SOURCE: SHARP AR-160 IS BLINKING H 2 WHAT IS THIS
Hi
Thanks for using FixYa. Error H2-0 means Fusing unit temperature error. This error occurs due to a bad fuser temperature thermistor please change the thermistor of heater unit, and also check the thermal fuse. This error also occurs when the upper heater thermistor is open or the fusing unit is not installed when the door is closed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Testimonial: "this was very helpful"
Have you tried to replace the toner???? Are you sure the light that is blinking for the toner?????
