SOURCE: only works on loadspeaker
The problem is with the socket where you insert the handsfree. Sometimes the socket connection is not released internally after removing the jack. Please insert the handsfree to its jack socket and remove it. Try again.
If not possible, a repair technician has to do it.
SOURCE: Motorola Bluetooth HS850 Pairing Mode
was soooo helpful just make sure u do flip it open immediately after, thats were i messed up... Thk
SOURCE: Can't hear anything in my bluetooth headset, mic is working
Hi--First, make sure your "mute" function is off. Try holding both volume buttons at the same time for a second or two. If that doesn't help, while you're having a conversation, either with or without bluetooth, make sure your phone's volume is turned up. On a lot of phones the volume button will control both ringer and conversation volumes, but turning it up without the phone in use only affects the ringer volume. My husband thought there was something wrong with his bluetooth until we noticed his phone volume was set too low--not as noticeable on handset, but bluetooth apparently needs volume up pretty high!
This worked great for me... I got the headset in "pairing" mode by following these instructions. Then set my BB Curve 8350i to "discover" bluetooth devices. It discovered the headset and asked for a PIN number... one of the other articles I read said the pin was "0000" so I put that in and - PRESTO - it works
