Several table top saws can have various worm gears incorporated into the blade height adjustment. It sounds like some of the gear teeth may be worn, causing slippage.
I would take an extensive look at underneath the table at the height mechanism. You probably will have to clean things up first since everything gets coated with sawdust mixed with lubrication ...
CHECK THE RETURN SPRING
SOURCE: Acer Aspire 5610 Bluetooth not working.
I may be wrong but acer laptops have the bluetooth buttons, but not always have the Bluetooth Module. Check the bottom white sticker for a bluetooth symbol under the laptop. If you do not see it, there is no bluetooth. Also, if you press/move the bluetooth button, and the light doesn't turn blue, there's no bluetooth module with your laptop (only the button), so your laptop did not come with bluetooth.
SOURCE: dual indash radio xdvd-8181
Hey guys I have a xdvd-8181 indash dual radio and the password screen comes up and i forgot the password that i set it up with so i was wondering if there is any way to reset it??? Any help will be appreciated thanks Anthony
SOURCE: Nokia 6300 Australia Vodafone requesting restriction code
Handset Unlock - Instructions
Please find below the instructions to unlock your handset.
Handset Unlock Procedure for IMEI:
353508029865248
Your unlock code is:
426850229882845
Manufacturer/Model:
Nokia_6300
Nokia 6300
PHONE UNLOCK PROCEDURE
PLEASE READ THE INSTRUCTIONS CAREFULLY BEFORE YOU ATTEMPT ANY
UNLOCK PROCESS
This procedure unlocks the handset from being network restricted from only
using SIM cards from Vodafone Australia. In
case of difficulties, please refer to the FAQ listed below
1.
Take note of the unlocking code shown above
2.
Insert a Non-Vodafone Australia working
SIM card.
3.
Ensure the phone is charged and then switch the phone
on.
4.
Optional
Step: If the SIM card has a PIN, enter your PIN number. (See FAQ below)
5.
The phone will then display a message. The most common
is “Phone
Restricted”. Select
“undo” by pressing the middle
soft-key button. (Different message? See FAQ below)
6.
Carefully read step 6 before
attempting to enter the unlock code. This step has the potential to PERMANENTLY
BLOCK YOUR PHONE!
Enter into the phone #pw+ followed
by the 15-digit unlocking code then +1#
(Unlocking code is shown above). Do not
enter the 15-digit IMEI number by
mistake
To enter +
press the * (star) key two times
To enter p
press the * (star) key three times
To enter w
press the * (star) key four times
For Example: If your 15-digit unlocking code is 123456789012345, enter the following in
sequence: #pw+12456789012345+1#
(When entering the unlocking sequence it
disappears? See the FAQ below)
7.
Then press “OK”
8.
The handset will display “Phone
restriction off”
unlocked after successful entry of the unlocking code. This will be confirmed if
you can make and receive calls with the Non-Vodafone Australia
SIM card. (You will need reception and phone
credit with the different network provider)
SOURCE: Raised RPM's cause Engine Whine
With Serpintine Belt OFF SPIN And Listen to ALL PULLEYS for any Noise they should be Quiet It almost HAS TO Be One of them. Tentioner Pulley ALSO. Please Reply Back to me We CAN Get this Solved
SOURCE: Saw blade turns real slow then breaker pops
motor is binding up. wait a day and see if it does it again
if so replace the motor
Testimonial: "Thank you!!!"
