SOURCE: broken lock on grill plate
If you find a source for a replacement locking handle, we would appreciate you letting us know. Likewise, we will let you know if we find a source. Thanks, [email protected]
SOURCE: bottom plate replacment
theres lots of posts here regarding george foreman products.
there does,nt seem to be anywhere to buy replacement parts.
I,d suggest buying a new alternative product, with a more stable background, and reliable service and replacement parts. i.e russel hobbs or tefal et,c.
Mike @ Compurepair.
SOURCE: Need a Manual & Parts List - BBQ Galore Turbo STS 4 Burner (LP)
I have the manual you are looking for.
Send me your email address and I will send it to you.
[email protected]
SOURCE: Can grill be safely converted to griddle on Thermador PRG486GLUS?
http://www.instawares.com/add-griddle-top-2.133-1002.0.7.htm
try this.
If it doesnt fit your specs. then i would suggest u find a thermador parts place and begin to buy the parts for the griddle as replacement parts. find a model of the stove set up that you want and make a list of all the parts that go to the griddle attachment.
My guess is that the reason for the flat "No" on the retrofit was that griddles require a thermostat similar to the one on the oven and broilers do not. So if their is no room behind the face plate where the knob would go then you can't put in a griddle. The other issue might be that the burners for the griddle wont line up with the brackets that are holding up all the broiler burners now. The griddle burner looks exactly like the one from the over only smaller so it has to line up strait where a regular front and back burner have to line up offset. maybe since you have the broiler already that should not be an issue? Then the problem is finding the griddle top it self that is going to be spendy. I think the link i gave at the top is your best bet. good luck.
Leslie
