Ive unplugged, and now plugged and it sounds like its draining..won't stop and door locked! help!
SOURCE: Kenmore He3Washer Fills then gives error code
remove lower panel right side underneath tech manual with codes
SOURCE: Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
SOURCE: Duet Sport Whirlpool front loading washer is
First check your washer plug to see if the connections are tightly
screwed. Next check your filter if you haven't for long.
Remove
the 3 screws at the bottom of the front panel under the
washer door. Your filter door will be light brown. If you find a hose
there it is to drain out excess water (water that could not be drained
by your pump) After you hv drained unscrew the cap and
remove all the junk inside. Have a large plastic bag to catch junk and
water. Refit carefully after cleaning out. If not solved, something
shd be blocking your pump, check this out
How abt a nice rating
for the free help? Thnks
SOURCE: door locked, won't turn on. won't reset
Remove the bottom panel which would give you access to the pump area if you look up along the side that the door lock is on you will see a cord with a loop on it pull this cord and the door would open. The panel must be removed in order to locate this pull cord. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks Rick
p.s if after you open the door and you were to leave the unit unplugged for 7 minutes if the error did not go away or if the door once again locked up you would have no choice but to replace the door lock assembly on the unit Thanks again Rick
Testimonial: "Good advice fast! Thank you so much for your time and expertise!"
