SOURCE: My NEC NW 652 washing machine is showing an E9 fault
E9 means the waterlevel sensor is defective or the pipe connected to it is faulty.
SOURCE: NEC NW 892 Errror E9
This error is related to the pressure sensor
check connections or replce pressure sensor
Check at the water source end of the hose and make sure the filter is not occluded. Both hot and cold. more likely the cold side as the hot water may disolve the particles more easily.
If all else seems good you will have to replace the sensor
SOURCE: Gd evng Sir. I am Krish.
Hi, in other Daewoo models E9 error code means pressure sensor failure. This sensor is used to know water level in the tube. It is probably that your model reports the same codes.
It does not necessary means a broken sensor you must check the electrical connectors and cables as well as all the mechanic and pneumatic elements like the hose connected to the sensor.
It is often clogs with soap and other particles and removing it should solve the problem....
SOURCE: I have a defy top
Error E9 means a problem with your water pressure sensor. Check the sensor by pulling the hose attached to the
bottom part of the tub and blow on it and test the terminals of the
sensor if it will close or open.
Hope helps.
SOURCE: Defy - 13KG Laundromaid 1300
Here's a solution I've gotten from one of the experts..
"Clean the drain motor lint tray/filter. So many 'faults' are
caused by blocked filters. The motor is unable to drain all of the water
in the allotted time.
If you are unsure where the filter is, it is normally behind the front
lower (kick) panel (or in some machines at the rear in an awkward
position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the
drain motor and ensure it is not jammed by a foreign object such as a
needle or a toothpick. It should be able to be turned by hand/finger-
the power IS OFF!
At this point it is also possible to test if the motor works. No clothes
or water in the machine, select a spin cycle and put the power back on.
You should be able to see the motor turning at some point, possibly
straight away. If it doesn't work then the motor is malfunctioning!"
Hope this helps.. Good luck! :)
