SOURCE: I cannot get my computer to stream trough the Wii
The Wii has its own netflix disc to install on the wii. YOu do not actually stream through the computer if you go to the netflix site you can put the wii disc in your queue and they will mail it to you. Once you have it install it as a channel and you can watch netflix on your wii.
SOURCE: streaming will not load from
There appears to be a temporary issue with the Nintendo Wi-Fi Connection. Our technicians are currently working to resolve this problem. Please try your connection again later.
If you have waited several hours and are still seeing this error code, please call 1-800-255-3700. Our representatives are available between 6:00 a.m. and 7:00 p.m. Pacific Time, seven days a week.
SOURCE: I am streaming netflix from
Hello, although there are not official wii to HDMI output cables, there are in fact some cables that are provided by third party handlers that will work.
For instance THIS product is a simple little converter which you put into your wii output and connect a regular HDMI cable.
KEEP IN MIND: This isn't a HDMI cable, you need to have a HDMI cable or buy one to use it with this product.
Netflix Instant is
available for streaming on your Wii gaming console by early spring 2010.
If you have a Netflix subscription you can watch movies and episodes
easily on your TV through your Wii console. This article will detail
the important things you will need to make sure that you can watch
Netflix from the Wii.
Difficulty:Easy
Instructions
Things You'll Need
wii generate lot of network errors ........ so don't worry, you
can solve this easily ..... i got some problem with my wii and its resolved by
the help of Repair Guide
it covers network problems thoroughly so check
this out !!
it will definitely helps you CLICK
HERE
