SOURCE: sony xplod 500w 4/3 channel
If the speaker is a 4 ohm DVC (two 4 ohm coils), you can't wire it to get a single 4 ohm load. Try connecting one coil to each of the two rear channels. It may not be as loud but the amp should operate without going into protection.
If the two 4 ohm coils are in parallel, the amp is driving a 2 ohm mono load. That's probably why it's shutting down.
SOURCE: Rockford Fosgate 120a2 amp
You can get it from Rockford.
Let me know if you need any help repairing it.
SOURCE: How much would installing a headunit, amp, and subs usually cost?
hows it going so you need it to be installed or you can install this yourself? well the best bet fund to get stuff done cheap is t get the stuf you will need to do an install like a install wiring kit and tools and post a installer help on craigslist.org iin your local area would be the cheapest way or just go to your local audio stereo shop thanks again and i hoope this help have any more questions please feel free to contact me if you need a step by step install i can help you in that and save you big bucks thanks again. always forward jcbproducts
SOURCE: Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
SOURCE: 401s Rockford Fosgate Amp. Not powering on,just protect lite is on.
the problem is mostly with your audio side of the amp. i have a 800 Rockford punch series amp hooked in series running at about 15 vdc at 2 ohms stable for now. but the amps left front power side transistors overloaded and smoked out, i will be replaceing my mosfets soon. Now on that side your issues apear to be related to the signal side of the amp. when you hooked the amp up tell me breifly did you hook the rca inputs to the back of the sterio and did you select the proper rca inputs for the amp? also note that amps have a potentiomater that can be tuned up or down to allow the volume or wattage to go up or down threw the system. if it's turned all the way down you'll here nothing. but often you'll get a pop sound or quickly see the speaker move a bit. this indicated the signal side of the amp has signal comming in but no output, just look for a turnable small screw inside the amp top or side. and turn up acordingly. note: to much output will damadge your system. not just the amp. ;)
