SOURCE: We have an LG SQ/SR/ST
i can figure out what model a/c you have from this discription/ is this a lg floor mod. or window model or lg duckless split system
one comon problem causing faut is dirty filter or condensor but hard to figure if i cant place the unit disciption.
SOURCE: c6 error on airconditioner
6 - DC Peak Error • Supplied power is not normal • Comp Connector (CN-U,V,W) is disconnected or inserted to wrong position • Compressor is damaged (coil short) ? replace compressor • Too much Refrigerant
• Defect in outdoor pcb assembly ? replace pcb assembly
Try turning power off to external unit, usually resets diagnostics and runs OK. If not PCB external unit likely culprit, replace!
SOURCE: indoor unit flashes 5 times. error code meaning?
I have a lg aircon model lsr122v-4 and when I turn it on it stays on for about 2 mins then turns off. Once it's off it flashes a green light 5 times and continues in intervals. What could possible be wrong with it?
6 - DC Peak Error
position
