No picture only menuwill show
SOURCE: Blue screen
Check the CRT.and then check if there is a loose solder on the whole board and also check the H-out..change the CRT socket which is Color White Connected to the Tube.
SOURCE: my tv only shows blue screen
what type of cable are you using? make sure all the video connections are tight. make sure the TV wasn't switched to a secondary video.
SOURCE: The TV only shows a royal blue screen. I can get
This would appear there is no incoming signal. Check your antenna or cable connection is connected securely & then try to retune the TV once more, you should pick up a picture. If not, if you have a DVD connected via a scart, check if you receive the DVD picture. If this is the case then there will be a problem within the tuner stage, possibly a replacement tuner will be required
