SOURCE: F9/FA Whirlpool 6th sense frontloader washer
F09 is "overflow failure" - check drain pump, pressure switch, blocked drain.
FA is the emergency shutoff switch that detects when water is pooling underneath the machine.
SOURCE: whirlpool duet washer leaks from
We just had the same problem. We took off the three screw on the back to remove the top panel on washer. From there we took the screws off the electric face plate on the front. Be careful, there is a screw located inside the door. You must open the door to get to the screw. Next we removed the bottom panel door and then the four screws to the mail metal panel on the front. Hold that panel because the rubber gasket is still connected. Then you will see a rubber hose directly under the drawer. Take the rubber hose off at the bottom nearest the drum. We found a sock that had wedged itself up and was causing a back up. After I cleared it, the washer works just fine.
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06
Drive
Motor Tachometer Error
The
control is unable to properly detect motor speed and the
machine will shut down. If a failure occurs during high-speed
spin, the door will be unlocked after 3 minutes.
Thank you for writing to fix ya.
Best regards Richard
SOURCE: My Whirlpool 6th sense washer displayed f09 so I
Thank you for your response. I finally managed to contact someone at Whirlpool who advised that the error code FA indicates a component problem and may require a replacement part. Unfortunately a serviceman is required.
SOURCE: my whirlpool front load washer leaks water from
Ours filled up with soap deposits. We simply took the drawer out and cleaned it and all is well. Hope this helps.
