Sharp LC65-N7000U
SOURCE: Main Power Board
The power supply board can be changed without any knowledge of repair but there are sometimes adjustments necessary if the picture is not normal. Many times it is fine. There a 4-5 voltage adjustments that would take some knowledge and a meter to accomplish. You need to hope it was diagnosed properly first. If it is completely dead the p.s is a good possibility. If it clicks on then back off almost immediately it is not likely the power supply.
SOURCE: WANT TO INSTALL MAIN BOARD ON SHARP LC52SE94U TV
Required board is available HERE and HERE
Click above links for price info.
Thanks.
SOURCE: I have a non-functional Sharp LC-32D62U (32") TV.
It would be possible if you can go into service menu and write all settings and implement with the new board by going back in and changing what you wrote down.
Stop the bleeding and replace the TV, I read this type of story so often, it is sad.
