SOURCE: Insert SIM Card
Put two layers of paper between SIM card and SIM holder to make it a tight hold.It solves your problem.
SOURCE: x sim card insertion with indian sim card insertion in i-phone
Some SIM cards because of their design have to be trimmed slightly in order to work with the turbo SIM. You can find a video on how to do this on youtube
SOURCE: How to insert SIM in Nokia N70
Take off the back battery civer, remove battery the sim slot should be under battery on most nokia models if you see no sim slot then your model is not GPRS its CDMA and requires a CDMA provider so check and make sure, Even tho you model may have one or the other there are two form factors to your model phone so this all depends on the formfactor and what system it was designed for. But like i said if you see no sim slot chances are its CDMA.
Best of luck to your please do rante and leave feedback ether way if you have any questions please ask, thank for using fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: how to open insert the sim card and how to open
with the screen facing you, the he sim tray on the iPhone 4 is along the right side half way down the metal frame. On all previous iPhones it is on the up center.
1. Once you have found your sim tray, insert a small paper clip into the hole
2. Slowly push in with even moderate pressure.
3. The tray will pop out and you will see your tray and sim card.
4. when replce=ing the card into the tray, the label side should be facing the screen side of the phone.
5. Repalce it by simply reinserting the tray the same way it came out.
