Tools & Hardware - Others Logo
R
Ronald F Haggart Posted on Jan 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a cantek C251 sander and the paper wont stay on
Dariusz Zalewski
Level 3:
  • Master 1,095 Answers
  • Posted on Feb 02, 2019
Dariusz Zalewski
Master
Level 3:
Answers
1095
Questions
0
Helped
297471
Points
3055
Need proper adjustment
Why is my 5" sanding disks not sticking to my sander?
The holes are to suction dust for a vacuum attachment or dust collection bag. The sander will have a very smooth pad almost shiny if it takes stick-on discs (PSA). If not it will be a velcro pad and in that case you need the velcro discs. This description sounds like you have a velcro pad. Sticky discs wont stick to a velcro pad.
How do I install paper to Skil Dual Action Sander model # 7372?
Sander has 2 slotted rotating rollers one on each end the paper gets fed in as you rotate roller, which will grasp paper and hold, feed/wind roller with slotted screwdriver till paper secure. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Skil nbsp7372 TYPE 1 nbspDUAL ACTION SANDER 348542
I am using the Porter Cable Quicksand Model 222 and the sander paper will not stay on the pad? What am I doing wrong...
first make sure you are using the right sandpaper for the tool and if it is hook and loop look at the pad for wear that will not allow the paper to adhere fully, if it is a PSA make sure the pad is not damaged.
1helpful
Can't figure out how to load the sand paper on to the mouse sander
Just stick the sand paper sheet to the base of the mouse sander... it's velcro it will hold... match the forme of the paper with the forme of the sander's base... that's all...
Cheers!
The sand paper wont stay on track anymore. It only stays on about half way. I have taken it apart twice and see nothing worn out or broken.
This was posted in "Problems with Chain Saws" .
i am just guessing here that this may be about a Belt Sander. if not the you should re-post and give more info on the machine. if it is about belt sanders then there is an adjustment screw for the belt tracking. The screw is in different locations for different brands. turn it on and adjust the screw until the belt is centered.
hope this has helped in some way, really need more info from you to give a better answer, sorry
May 14, 2011 • Garden
1helpful
This maybe a stupid question, but how do you get the sandpaper on and off of the sander. I borrowed it and I don't have a clue how to get it to stay on.
It depends on what kind of sander it is. If its a belt sander then on the side there is a lever that comes outward. it releases the tension then slip the old one off and new on and push lever back in place. If its a palm sander then on each side of the pad there will be 2 silver rods there. you push the rod in and then pull up and it releases a bar that wil go up and down for you to put the new paper on with.
Hook sand paper will not stay on the disk of the 5" palm sander
The backing pad does not last very long on these hook and loop designed sanders, and the pad should be replaced when the edges of the pad look worn. If the edges are okay try taking a toothbrush and some degreaser (IPA or brake cleaner). Look for the replacment backing pads online or at a hardware store.
4helpful
How do I change the sanding belt on my 7447 belt sander
To change the belt, you must release tension of the rollers by pushing the front roller straight back until you hear it click and lock in position to change paper. Remove old paper and replace with new paper. Make sure if new paper has directional arrows to install properly.
Now you must release the front roller to put tension on paper. To do this push the front roller from the side that has the adjustment screw. This will release the front roller and allow it to go back into position. Be careful as it pops back quickly and with some force.
Turn on sander and adjust centering of paper with adjustment screw found near the front and side of sander.
1helpful
Sandpaper does not stay in place
re align the end rollers as one of them will be out
Top Sander Tools & Hardware - Others Experts
vince
Ngoro
Are you a Sander Tool and Hardware - Other Expert? Answer questions, earn points and help others
