your copter might have already experienced some hard bumps or landings , so you might need to check your copter circuit and battery cables to make sure they are in good condition or check the battery itself.
Forgive me for saying, but has it definitely got gas in the tank? Run it on reserve tank if not. Check that the HT lead has not come off the spark plug. Ensure the lights come on with you turn the ignition on.
Shout back if this doesn't help, vote for me if it does :) Thanks.
..according to Moultrie, you MUST send it in with a VALIED receipt and $25 and they will reprogram it...NO EXCEPTIONS. I am also looking for a way around this; bought two used cheap with this prob. And of course my receipt is not from an authorized dealer.
Questions: 1) Is the bar plugged into the console? 2) Did your cat or dog chew through the wire? 3) Have you tried using the setup menu to alter the remote's sensitivity? 4) Is anything interfering with the sensor bar, such as a reflective surface or other lighting in the room? Shiny coffeetable tops and fluorescent lights aren't friendly to the Wiimote. Try covering reflective surfaces and playing with the lights off. 5) If you get a replacement and still have the same problem, then the problem is with the Wiimote.
