Before this message it was cartridge cover not latched
SOURCE: Epson rx580 printer
I just started calling Epson's customer service line every time. They always offered to FEDEX new ink. I got tired of waiting for it to come and began returning bad cartridges to office depot where I had bought it and found out that they will take it back if it doesn't work. Now I've decided that some (a lot) of Epson's ink cartridges for the RX580 are bad and that I just have to keep trying until I get ink cartridges that work. I had tried the qtip cleaning, checking the ink/sensor connection, and making sure I had them snapped in tight. I've finally figured out it IS the ink. BTW, I always use the ink Epson reccomends, so it is definately that many of their cartridges are faulty. It's a pain to have to return them but as long as I can return and replace them and eventually have a machine that will print when I need it to, I can live with that.
SOURCE: hp psc 2110 incorrect ink cartridge message.
when ever i get that message it's when i use a "Non-HP" replacement cartridge...try using a HP catridge, or most likely, the printer has reached the end of it's usefull life!
you can try a "full reset" of the printer by..
-unplug it and let sit for a little while,
-BEFORE plugging it back in, press and hold both the enter and cancel buttons,
-plug the power cord in, and wait to release the buttons until the display on the printer tells you to,
-in many cases, this corrects some problems (especially that awfull grinding/ratcheting noise).
after many years of faithful service, i think mine is officially dead though...even the full resxet doesnt help.
SOURCE: the ink cartridge cannot recognized (refilled 3 times)
i am having canon pixma ip1300 inkjet printer. it worked properly till 13th april 09 i got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to make my printer work again. give me the remedy as quickly as possible Thank you
SOURCE: epson rx680
one ink cartridge is out of ink but...
when we try to replace one of the color ink cartridges we get this error message:
ink cartridges cannot be recognized. make sure ink cartridges are installed correctly - how do I get the printer to recognize my full ink cartridge?
SOURCE: ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that
should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
