Computers & Internet Logo
A
Anonymous Posted on Jan 16, 2019
How do I solve the rtl120.bpl missing problem in windows 7?
Peter Dragonetti
Level 3:
  • Master 798 Answers
  • Posted on Jan 16, 2019
Peter Dragonetti
Master
Level 3:
Answers
798
Questions
Helped
209347
Points
2183
5 Related Answers
Anonymous
  • 51 Answers
  • Posted on Feb 17, 2010
SOURCE: What is rtl120.bpl. A box appeared whenever I
The error could be connected to the advanced system care. Have you uninstalled any protective software lately?
It would seem that as the computer is starting it is trying to load a program that is either corrupt or missing, generally a program like reg cleaner or other utility program.
If its a case you have removed a program, try installing it and see if that works.
Get another copy of the advanced sys care program and reinstall that.
If this doesn't work, get back to me.
Anonymous
  • 120 Answers
  • Posted on Jun 19, 2011
SOURCE: The program can't start because
Google 'download rtl120.bpl'.
Download the file from the list and put it in C:\WIndows\System32
You may be asked for other libraries too. Just do the same thing to get them.
tbirdfan1
Michael Thomas
  • 3056 Answers
  • Posted on Mar 22, 2012
SOURCE: IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
General Systems Consulting
  • 5051 Answers
  • Posted on Apr 06, 2012
SOURCE: how do i reinstall rtl120.bpl
Listen, I love AVG Free Virus Protection, but their PC Tuneup is junk. Don't put junk on your system.
Anonymous
  • Posted on Sep 02, 2012
SOURCE: rtl120.bpl is missing
n http://search.sweetim.com/search.asp?q=http%3A%2F%2Fwww.opendll.com%2Findex.php%3Fsearch%3Drtl120.bpl&ln=en&src=1006&crg=3.1010000&st=10&sf=0
Download rtl120 bpl
Do a Google-search for 'download RTL120 BPL Windows 7', and follow the links.
3helpful
What isrtl120.bpl
it may be the problem with your harddik or ram.First you try to reinstall windows.If you can't install check your HDD usin HDD regenerator
8helpful
2answers
The program can't start because rtl120.bpl is missing from your computer. Try reinstalling the program to fix this problem.
2helpful
My Computer missing rtl120.bpl
Jan 06, 2011 • Watches
Top The Computers & Internet Experts
Alexander
nexrad_chris
vince
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
