Which is the best powdered cascade product for the china/crystal setting on my miele?
Most european dishwashers are water conserving and energy saving. You have to be very careful in the type of detergent that you use. Plain, original cascade powder works fine in your Miele. Use 1/2 of the recommended amount, as your dishwasher uses much less water than the american machines that the amounts are written for. avoid cascade with additives such as bleach, or dawn. these additional components in the detergent do not rinse off well with the reduced water quantity, and will leave a gritty white residue on your dishes. Stick with the plain powder. I use Finish tablets with the red powerball, and I dont add rinse aid. These tablets work great in the Miele, asko, Bosch, and other imported dishwashers.
One caution on your china and crystal setting, your manual states that if you want to use the china and crystal cycle, the dishwasher should be connected to cold water only. The temperature of the china and crystal setting is limited to 115 degrees. your hot water is probably much hotter. if your dishwasher is connected to hot water, it will defeat the purpose of the lower temperature cycle. you will get etching on your crystal glasses.
Remember, the Miele will heat its own water one batch at a time. Connect it to cold for energy efficiency, hot for shorter cycle times. but cold only for china and crystal.
Enjoy your machine.
