Televison & Video Logo
N
Nicole Brittingham Posted on Jan 16, 2019
How. Do I program mynrmadu138 remote to my other devices
tip
Programming Philips Universal Remote Control To Your Device
Program the Device by Entering Direct Codes
1.Turn all of your devices off, and then manually turn on the device you want to program.
2. Press the Setup button on your the universal remote and continue to hold it down until the indicator light stops flashing and remains solid.
3. Release the Setup button
4. Press the button to which you want to programme(TV/VCD/DVD).
5. Release it immediately and make sure the indicator light is illuminated.
6.Enter the first possible four-digit code on the universal remote, and then press another button on the remote to see if the device is now programmed, such as the volume control or power button.
7. If the device responds, you have successfully programmed your Philips universal remote.
8. If the remote is not programmed then, turn the device off and back on and follow the steps again using the next code on the list. Repeat until the device successfully responds.
How to Program a Remote Using Code Search
1. Turn all of your devices off, and then manually turn on the device you want to program.
6. Press either the Channel button or the Play button until the device responds. Each time you press the button, the Philips universal remote tries a new code.
7. When the code works, press the Mute button on the Philips universal remote and the code will be stored.
To Get The Programming Codes :
Please go to below website to get the codes to programme your remote.
http://www.urc.philips.com/
Please select the below informations.
1. Location
2. Select your remote model.
3. On your left side you will have an option called as REMOTE CONTROL CODE FINDER.
Attached a image for your reference:
4. Select the device you need to programme and the make of the device you will get the codes for your device.
Thank you
on Jul 27, 2010 • Televison & Video
2answers
Need to reprogram GE remote to Samsung tv
GE Universal Remote Codes ' Jasco
https://jascoproducts.com/support/ge-universal-remote-codes
A version 2 through version 4 remote will have a "V2" to "V4" after the model number. ... Program your GE Universal Remote using the correct code list and ...
GE Universal Remote Codes and Instructions ' direcTutor
www.directutor.com/content/ge-universal-remote-instructions
Direct Code Entry for GE remotes with 4 digit codes. 1. ... Press and release the button for the device you are programming (TV, VCR, DVD, etc.). For AUX, press ...
How to Program a Universal Remote - Frontier
internet.frontier.com/resources/how-to/program-a-universal-remote/
Here's how to program universal remotes from RCA and GE: ... with whatever device you're currently attempting to program (i.e. the TV, the DVD player, etc.) ... If you havea V2, V3 or V4 remote and are programming a DVD player, press PLAY ...
How To Program A GE Universal Remote ' Codes For ...
codesforuniversalremotes.com/program-ge-universal-remote/
Need Time Warner remote codes for a TLC TV
There are no Time warner codes for TCL tv's. You will have to perform a "code search"
1 Turn on the device that you wish to program. If you are programming a DVD or VCR player, then insert a media disc such as a DVD or VHS tape.
2 Press the device key on the remote once. This remote is capable of programming five devices, and each has its own respective button at the top of the remote. For example, if you wish to program a TV, press the "TV" device key at the top of the remote. The device key will blink once.
3 Press and hold the "Setup" button on the remote. The selected device key will blink twice, indicating it is ready to be programmed.
4 Enter "991" on the remote. The device key will blink twice again.
5 Aim the remote at the device you wish to program and press the "Power" button.
6 Press the "Channel +" button on the remote. Continue to press that button until the device turns off. Once that happens, press the "Setup" button to lock in the code.
7 Press the "Power" to turn the device back on and it will be ready to use
6helpful
How do you program a Dish Network Remote to control a DirecTV receiver?
  • 1 Turn on the electronic device for which you'll be using your remote control. You will have to do this manually by pressing the "On/Off" button on the device.
  • 2 Locate either the "Code Search" or "Setup" button on your remote control. Which one you have will depend on the remote control.
  • 3 Hold that button for anywhere between five and 10 seconds. The light on your remote should then turn on. Depending on your remote, the light will either blink or remain on after you release the button.
  • 4 Press the corresponding button on your remote for your device that you are programming. In other words, if you want to program your remote to your television, you would press the "TV" button.
  • 5 Use the numbers on your remote to enter the three- or four-digit code for that particular device. The codes for your remote control will be found in the manual. Don't worry if you have lost the manual. You can find codes for practically every remote control on the market on the Internet. Visit the website of the manufacturer of the electronic device (TV, DVD player, among others) or log onto the "Universal Remote Control Codes" website. Once you have entered the code using the remote, you should notice that the light on your remote has turned off.
  • 6 Point your remote towards the device and attempt to turn the device off. If you can do so, you have programmed your remote correctly.
Programming Without Remote Control Codes
  • 1 Repeat Steps 1 through 4 found in Section 1.
  • 2 Begin pressing the "Up" channel button found on your remote. You will probably have to do this a few hundred times (or anywhere between five and 10 minutes). Once the channel changes, your remote will be programmed. Turn the device on and off using your remote to finish programming.
  • 3 Use the "Power" button if the channel button did not program your remote control. Again, you will probably have to press the "Power" button a few hundred times. Once the device that you are programming your remote to has turned off, you will know that you have programmed the remote control correctly.
2answers
Ok i have a rca remote trying tp program it to a emerson tv do not have any codes
Here are some codes for your Emerson TV.
065,067,075,076,079
011,026,027,028,029,030
031,032,037,042,053,064
Here are some instructions as well for your RCA Remote:
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Hope that helps.
5helpful
Need remote code for symphonic tv. Have living solutions giant remote
    Programming a Living Solutions Universal Remote
  1. Step 1 Turn on the component you wish to sync to your universal remote--your television, DVD player, VCR or stereo.
  2. Step 2 Point the remote at the device you are programming and press the corresponding device button on the remote. These buttons are labeled "TV," "VCR", "DVD," etc. Hold the device button for three to five seconds.
  3. Step 3 Push the power button on the remote. This should turn on the device that you are syncing.
  4. Step 4 Push the "Channel Up" or "Channel Down" button on your remote gradually until the device that you are programming shuts off.
  5. Step 5 Press "OK" or "Enter" on the remote once the synced device turns off.
  6. Step 6 Press the device button for the component you just programmed, and hit the power button while pointing the remote at the component. If programmed correctly, the device should turn on, and you should be able to control it with your Living Solutions Universal Remote.
1helpful
2answers
Programming a remote
7helpful
3answers
RCA Universal Remote set to my Emerson TV
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
What do I have to do?
Introduction Programming a Jasco/GE Universal Remote Control takes about seven steps. As with programming other remotes, you need to know the code of the component you are programming into the remote. While some trial and error may be required to get the right codes input to control your equipment, the pleasure at getting rid of several extra remote controls will far outweigh the hassle in getting it programmed. Instructions Difficulty: Easy Steps 1Step OneManually turn on the device you wish to program. 2Step TwoPress the Code Search button on the remote until the indicator light turns on. 3Step ThreeRelease the Code Search button. 4Step FourPress and release the button for the device you are programming. 5Step FiveEnter the three-digit code for the device using the number buttons on the remote. After the code is entered, the indicator light turns off. 6Step SixAim the remote at the device and press the power button. The device should turn off. 7Step SevenPress Channel Up on the remote with the device on. If the device responds, no further programming is required. 8Step EightTo look up a device code to enter directly into the remote, you can visit the GE Remote Code Locator SAMSUNG 002 012 102 103 112 212 502 512 818 914
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
