SOURCE: DVD stuck in sony blueray player bdp s300
Step1There are a few ways to get your dvd/cd drive release itself. The first thing you should try is shut your equipment completely off for a couple of minutes allowing it to cool down. Once you turn it back on try to press the release button on your equipment. Step2If that does not work try to use a very thin flat tip screwdriver. Insert in on one of the sides of the dvd/cd drive and try to pull it out softly while pressing the eject button simultaneously. Do not force it out but give enough pressure while pressing the eject button. Step3More than likely inserting a screwdrive should release the dvd/cd drive. You can also try a butterknife as well just don't use to much force. Something else to check for is to make sure the power is acutally on for the device. If you are trying to open a drive that is not even on it will never open up for you.
SOURCE: How can I unlock the region code for my Sony BDP
go to esupport.sony.com for latest firmware upgrade.
SOURCE: Code to enter on remote
I have the same problem with the Sony SBD-s360 blue ray and the Verizon Fios remote. Not codes work and I tried over 1000 search codes with no luck. Verizon needs to replace the remote with a later model
SOURCE: how do you update a sony blu ray player bdp-s300?
You can Update the Firmware of the Blu-ray Disc Player(BD Player) in two ways.
1. By downloading Firmware update and burning it to a CD-R disc if you have CD Burner in your Computer.
a)Download the Firmware update from Sony website for free to your Computer and then burn it to a CD-R disc by following the instruction mentioned on the download page.
b) Insert the burnt disc into the BD Player and follow the on-screen instructions to install the Update.
Please click on the link and select the correct Operating System installed in the Computer to which you are going to download and burn the Update. Then, click on Download icon to download the Update.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=BDPS300&SelectOS=27
The detailed instructions are mentioned on the page.
2. Second, if you do not have a CD Burner in the Computer or you do not wish to download and burn the Update, then you can contact the Sony Customer support to order a FREE UPDATE DISC. They will ship the disc to you free of cost.
