SOURCE: Transmission Problems
Is it missing reverse 2nd and 4th? If so it has a broken reverse reaction shell. They aren't too hard to replace
SOURCE: car drives fine in first gear but slips completely in 2 3 & 4th
Auto matic or standard ????If standard, the clutch is shot, if automatic the clutches are slipping may be low on transmission fluid, check first.
SOURCE: TRANSMISSION 2nd to 3rd GEAR HARDSHIFT
SOURCE: 2000 dodge diesel 3500 6 speed manual
I am going through this now my 2000 ram 3500 always had a problem with reverse I chocked it up to a quirk of the transmission! But my mechanic found out that they only placed this trans in late 1999 and early 2000 trucks first years the 6 speed was offered. It comes with a smaller clutch and synchronizer that are no longer available unless you find a dealer with old stock sitting on a shelf. I am having to updated my cultch and am having to replace the gears that will allow the new type synchronizer to work this in just a about ½ the price of a new transmission BOHICA/FUBAR So just get ready for a shock if you need to replace synchronizer rings
SOURCE: Shifting solenoids on 2002 Lancer.
For Automatic transmission
problem,click the link below:----
troubleshooting:----
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html --------- http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html ----------- http://schematicsdiagram.blogspot.com/2011/07/how-to-check-automatic-transmission.html -------------- AUTOMATIC TRANSMISSION FLUID AND
FILTER? http://schematicsdiagram.blogspot.com/2011/07/how-to-change-automatic-transmission.html ----------- http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html -------- http://schematicsdiagram.blogspot.com/2012/01/transmission-shifting-problem-on-toyota.html -------- http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html ----------- http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html ---------- http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html ---------- http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html ------------- http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html ------------- http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html ---------- http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html ----------- This
will help. Thanks.
Automatic transmission shift lever
issues?-------
AUTOMATIC TRANSMISSION FLUID LEVEL? --
Transmission fault light on
car dash?
Transmission shifting
problem?
Transmission Slips out of 2nd gear?
OD light flashing and transmission fluid
leaking?
Why Transmission fluid leaks near radiator?
Transmission fluid leaking?
****** wont go in reverse?
Automatic transmission will not go into
reverse?
Transmission is making buzzing noise?
