SOURCE: vizio p50hdm loud pop from inside tv now screen is dim
Hi there! This could be as a result of several boards. Y-sus, Z-Sus or power supply. One would need to check that all the relevant Voltages on the power supply are actually present. Next would be to check the Fuses on either Y or Z-Sus boards. The board with the fuse blown would most likely be the one at fault. However it blows for a reason so replacing the fuse on these boards will probably not help. But it is worth a shot. If all else fails refer to a repairer. If you can get the boards and want to try doing it yourself it may or may not prove to be successful. Please beware of HIGH CURRENT before you proceed. Best Wishes and Good Luck, JUS004
SOURCE: My toshiba 42" REGZA 42RV535U
U have sound but no picture?Picture does flashes a few sec?Yes,than those 2 long LCD inverter boards are dead.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
SOURCE: Horizontal lines pop in sound on certain channels
Check all of your ground screws on the boards that you replaced. Sounds like that once the set is getting hot, the board is expanding and shorting out on the screws.
