Dogs Logo
G
Gary lemay Posted on Jan 16, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi my dog just ate a grape. He is 20 lbs bichon freices shitzu mix 2 yrs old. We gave him about 7 ml of hydrogen peroxide 12 minutes ago
Cory Rhonda
Level 1:
Habit-Forming:
  • Contributor 61 Answers
  • Posted on Sep 10, 2019
Cory Rhonda
Contributor
Level 1:
Habit-Forming:
Answers
61
Questions
0
Helped
20115
Points
92
Mine has eaten over a lb of grapes b4 with no negative effects
Jean DeLauche
Level 3:
  • Master 2,911 Answers
  • Posted on Jan 16, 2019
Jean DeLauche
Master
Level 3:
Answers
2911
Questions
Helped
975633
Points
13030
Hello, Gary -
Call your veterinarian's office right away and ask your question.
Fixya.com, where you posted your question, is a website intended for asking and answering questions on how to go about REPAIRING THINGS.
Best wishes.
  • ZenFire Apr 24, 2019
    The category is Dogs, so your answer about fixing or repairing THINGS does not apply, and to be honest is rather rude.
  • Jean DeLauche
    Jean DeLauche Apr 25, 2019
    Hello, ZenFire - I am sorry you think my answer was rude. I advised the questioner to contact his veterinarian right away. I believed his was a "time sensitve" question. For the most part, veterinarians and veterinary assistants, would not see the question on this website. My comment about the purpose of the Fixya website was to clue the questioner to its major purpose. Posting the question on a website specifically regarding health care issues for dogs and which is actively monitored by veterinary professionals would have a been a better option, in my opinion, if a call to the veterinarian did not help the questioner and his dog. Have a day.
5 Related Answers
Anonymous
  • Posted on Nov 22, 2009
SOURCE: 2 year old Brother MFC 3240C = Black is plugged
I getting rid of mine with the same problem. No more Brother products.
Anonymous
  • Posted on Mar 29, 2011
SOURCE: I'm using Goldwell 12BG which
Ratio is always developer to color, so a 2:1 is 2 parts developer to 1 part color. Example mixture is 40 ml developer to 20 ml color.
30 vol gives you better control and less damage to your hair. If you have VERY dark hair (level 5/4 or below), you need to pre-lift and then apply the color. It sounds like you're not a trained stylist, so I don't recommend 40 vol as it lifts too fast for most people to get an even application, especially if you're applying it to your own head (since it takes longer to do generally speaking).
You can work in sections to preserve color and get a more even application. Simply mix enough color for one section at at time, apply and process, then rinse ONLY that section with water to stop the chemical process. Repeat on all other sections. Good luck!
Anonymous
  • Posted on May 27, 2011
SOURCE: my shallow well pump will not pump to 40 lbs
Installed new shallow well pump still only can get to 30 lbs pressure. when i turn pump off pressure drops to 20 lbs right away and stays there
Anonymous
  • 2080 Answers
  • Posted on Jan 11, 2012
SOURCE: Which of the following compounds in the liquid phase can be considered an electrolyte
NaCl (Sodium Chloride) is a strong electrolyte, and H2O (Distilled Water) is a weak electrolyte.
Therefore the answer should be B and C.
Here is a link to a helpful website with some further useful information about ELECTROLYTES:
http://www.science.uwaterloo.ca/~cchieh/cact/c120/electrolyte.html
I hope that was helpful.
Good luck and take care.
Joe.
Anonymous
  • Posted on Feb 23, 2012
SOURCE: I need the manual for a 1988 Hino Rainbow CH160A With a : WO6E Hino Engine, I am trying to lean out the fuel mix from the injectors to compensate for a hydrogen conversion kit
Dear Conway san
http://vicbus.com/portfolio/hino-rainbow-ch160/
Can't you get the manual in English from this Australian company since it seems to be selling that type of bus?
Take
Getting rid a fungus gnats throughout the house and killing houseplants
Mix one part 3% hydrogen peroxide with four parts water. Allow the top layer of your soil to dry, and then water your plants with this solution as you normally would. The soil will fizz for a few minutes after application; this is normal. The fungus gnat larvae will die on contact with the hydrogen peroxide.
Feb 11, 2018 • Garden
tip
How do I Clean iPod Ear buds
<p>IPod ear buds can get grungy from regular use and should be cleaned and disinfected frequently. If your iPod headphones with others, there is potential for the transmission of germs and infections. Be sure to immediately disinfect your earplugs if someone uses them. <br /> <p><br /> <p>Soap and water clean <br /> <p>1. Disconnect the headphones from the iPod. <br /> <p><br /> <p>2. Mix a mild soap with warm water. Dampen lint-free cotton with soap and water mixture. Wipe the earphones with a damp cloth. Do not get water into the holes. <br /> <p><br /> <p>3. Enter the cloth under warm running water. Rinse to remove all soap. Twist the cloth to dry. Wipe the earphones to eliminate soap residue. <br /> <p><br /> <p>4. Rub a clean, dry cloth over the headphones to dry them. <br /> <p><br /> <p>Disinfection with hydrogen peroxide <br /> <p>1. Buy a solution of hydrogen peroxide 3% or disinfectant wipes. This product is available in pharmacies and supermarkets. <br /> <p><br /> <p>2. Dampen a clean lint-free cloth to clean the peroxide and the headphones. <br /> <p><br /> <p>3. Wipes clean with a pre-designed for cleaning hearing aids if you do not feel comfortable using a solution of hydrogen peroxide. These scarves are not guaranteed damage plastic, silicone or rubber. <br /> <p><br /> <p>4. Carefully wipe the headphones with a clean, lint-free. <br />
on Aug 09, 2011 • Apple iPod touch
My 7 year old, 10 pound doxy ate a frozen tart cherry about 10 minutes ago. What do I need to do.
Alas, we are separated by language. The definition of doxy on the web rather dumbfounds me. It should astonish you when you look it up.
Yipes, you must mean dachshund. Here is just what you need to know:
Can Dogs Eat Cherries
In 10 minutes, the top three finishers in a hot dog eating contest consumed a total of 143 hot dogs.?
it is like- x+12+x+x-7= 143
solving the above equation, we get, x=46
which implies, A consumed x+12= 46+12= 58
B= x=46
C= 46-7= 39
If you need more help in your homework, contact Assignment Help 4 Me Get Rapid Homework Help from Professional Tutors
Jan 04, 2017 • Homework
My dog who is 20 lbs ate 2 benadryl is thst going to hurt him
I seriously doubt that the dose of Benadryl you gave which equals 50mg will cause nothing more than drowsiness and temporary lethargy. My 25lb dog gets 50mg Benadryl most summer days for her allergies and she has no ill effects.Unless your dog has some underlying condition she should have no long term damage to her health.
I'm using Goldwell 12BG which says 2+1 on the box. Is the formula 2 oz. of developer/peroxide to1 oz. of toner or is it 2 oz. of toner to 1 oz. of developer/peroxide and should I use 20% or 30%...
1helpful
I have whirpool hot water heater mmodleezf 40RDO45 V six months ago I had to buy and new anode and now the water is stinky again like rotten eggs, am I going to have to buy a new one every six months? ...
The smell is from bacteria.
1) The tank needs a new anode rod, but it also needs a periodic dose of hydrogen peroxide.
Recommend you reconfigure incoming water pipes where you can easily add 2 bottles of hydrogen peroxide and then flush water heater each 6 months. The peroxide kills the bacteria. Peroxide is not harmful to you since it is also used orally. You don't drink a bottle of peroxide, but it will not cause harm in trace amounts left in water heater.
2) There is something else to consider. If yours is a 12-year tank or lifetime tank, then you probably have 2 anode rods. Replacing one anode rod will not solve problem.
3) Another solution is a power anode rod. If your tank has two anode rods, then replace one with powered anode, and then remove the second anode rod.
According to the seller, he's had only one person where the water heater smell came back.
Here are links to information and to the powered anode rod:
http://www.waterheatertimer.org/Replace-anode-rod.html
http://www.waterheaterrescue.com/pages/WHRpages/English/OrderPages/XCart/Power-Anode.html
Manufacturers are starting to add powered anode rods to their top models to assure longer tank life and better customer satisfaction.
Add a comment if you need more help.
Top Dogs Experts
Canadian VC
Canadian VC
Thomas Perkins
Thomas Perkins
Billie Aukuso
Are you a Dog Expert? Answer questions, earn points and help others
