On two different computers the dvd stops playing after a few minutes
If you can gain access to the internal unit, do so. You will see a ribbon tape that goes from main board to near the eye of laser. Carefully pull the ribbon (some have a small clip on top to flip up, then remove), clean the silver contacts. Do the same on other end. This works in almost all cases! Matt of Martins TV Repair.
SOURCE: dvd will not play in dvd player but will play in computer
I use clone DVD to rip commercial or other DVD's I own onto my hard drive, and from there I use nero to burn them on a new DVD. It works for me. Basically what i'm saying is that as long as you have the right setup of files, in the right DVD file format, your DVD player will be able to play the movie. It doesn't matter if its from the internet. You the files to be in VOB and IFO format, and the Disc needs to have all the files that cue the player on the order of play etc. I suggest you download CloveDVD or any other DVD ripping software, and note the file breakdown you get on the output, and make sure that what you download looks the same. Some DVD players offcourse can play VCDs and DIVx formats(many of the .avi are divx), you should know about yours, I dont think you can alter it. Good luck
SOURCE: Plays CDs but not DVDs
Melisha, I had a similiar problem. Go into the onscreen menu with the remote using the "ACTION" button on the bottom left of the remote. Using the arrow keys in the center of the remote, move to the menu for the audio processing. It will have menu items for DTS, Dolby Digital etc. Change the menu parameters for the "Down conversion" to "yes", get out of the menu mode and see if your DVD works again. If not, make sure there is no DVD or CD in the player, and press the "open/close", "pause" and the double left pointing arrow buttons all at the same time for about 5 seconds until the display on the DVD player says "INITIALIZE". This resets your machine. I hope this helps you.
SOURCE: jvc xv-s332 dvd player won't play
on the back is a seitch labelled ntsc/pal. flick it the other way might fix it
SOURCE: playing recordable dvd
I play recorded DVD-R and DVD+R on mine all the time. It only plays true DVD Video formats, so if your trying to play a windows media file anything other than a true DVD Video, it won't happen on this player. It supports DL also in the correct format.
SOURCE: DVD player picture freezes
hi u can purchase a sony DVD lense cleaner which can make ur dvd player lense perfect for running various kind of dvd... pls rate me
