Televison & Video Logo
A
Anonymous Posted on Jan 15, 2019
How to add channels to dyex tv - Dynex Televison & Video
timoboon2
Level 2:
Sergeant:
  • Dynex Expert 360 Answers
  • Posted on Jan 16, 2019
timoboon2
Dynex Expert
Level 2:
Sergeant:
Answers
360
Questions
0
Helped
154614
Points
959
That depends. Most older televisions can't handle more than 99 channels. Also your cable provider will set the amount of channels you can receive.
I want to save the channels and turn my antenna to another direction and scan I loose the channels that I had can I save them some how?
The only way that I solve this issue is to write down the channels available from one direction on paper. Do the scan in the second direction. Return the antenna to the first direction and then manually add the rest of the channels. Depending on the TV, you either type in the channel number with the remote control or find a Add Channel option in the TV Channel sub-menu.
At least with my TV that doesn't have an Add Channel option in the Channel section, going to a digital channel with the remote doesn't store the channel number if the signal isn't strong enough for the tuner to resolve. Analog channels can be added when the signal is poor.
If you know all of the local channels in each direction from AntennaWeb ( http://www.antennaweb.org ) or TvFool
( http://www.tvfool.com ), you can use that documentation to add the channels at each antenna direction.
I hope this helps. If you use an electronic antenna rotor with a remote control, you may be able to program turning the antenna automatically when you change the channel. Check the documentation for the device to program this.
(Note: on my TV that adds channels only when I type in the channel number, recorded digital channels can disappear from the list if if I visit a channel with poor signal strength. Until the antenna is directed towards that transmitter, I can't add the channel back into the list.)
How to add channels
Try doing the auto scan first to get all the possible channels.. Usually the Add/Delete function applies once the TV knows what channels are out there to add or delete.
2answers
What buttons do i press to add/delete channels on emerson tv model# EWC1304? I cannot seem to get pass channel 2. I have no remote.
I have the same problem, my tv will not allow me to change channels but will only let me add/delete the channel the tv is currently on
How do u add and delete channels on a rca 24F512T
1) Make sure that the current input is TV. Then press Menu on either the TV or the remote.
2) Press Ch+ or Ch- to highligh Setup then press OK.
3) Press Vol+/Vol- to highlight TV or CATV as needed for the channels you wish to add or erase.
4) Then use Ch+/Ch- to highlight Channel and then press Vol+/Vol- to enter the channel number that you want to add.
5) Press Ch+/Ch- repeatedly to highlight Add/Erase then use Vol+/Vol- to select whether to add or erase the channel selected above (step 4).
6) Press Menu repeatedly to exit the OSD (or wait until the OSD closes after a period with no key presses).
Then use the Ch+/Ch- buttons to scroll through the channels in memory to see the change.
The manual for your 24F512T is available here: http://support.ttetech.com/RCATV/Assets/pdfs/24F512T_1641309F_IB_e-06.pdf . See page 13 of the manual for extra information on manual tuning and page 15 to add and remove channels from the channel list.
I hope this helps.
Finding the 'gaming' or 'aux' or 'av' channel
either find input button, or channel av1 or av2 or use channel add/delete in the menu and go back from channel 2 and once it's there, add it.
Or you can turn the device on, use the autoprogram feature and the tv will add all available channels.
I have a Phillips PC7225 C121 ..I programmed it to a universal remote and went to menue.. it says Barker, Channel, Firmware ..I put it on channel but cant get to do anything after that...what do I do... I...
I need to add channel 66 to this tv and it only goes to channel 60.- the remote or the tv.?.
if remote doit mannuly on the tv.
if tv. .............................
3answers
Add or delete channels on LXI tv
I have a Phillips LXI 46in TV. How do you save channels?
1helpful
Can't tune TV to channel 3 inorder to recieve digital tv
go into the menu & add that channel back on
somehow you deleted it
go to menu channel add/delete
Top Dynex Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Jesse Walters
Jesse Walters
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
