MOTORCYCLE HARLEY PANHEAD or HONDA>? pan European.
? IS NOT A CAR.
WELL IF BATTERY IS GOOD AND STARTER IS GOOD
THE ENGINE IS SEIZED?
ON mc ENGINES WE REMOVE SIDE COVERS AND HAND TURN THE CRANK SHAFT MAKE SURE IT CAN SPIN.
SO WAS PARKED OUTSIDE OUT DOORS FROM MONTHS OF HARD RAIN,IS NEVER GOOD FOR ANY MOTORCYCLE EVER.
OR SHIFT TO 4TH GEAR (1:1 GEAR) AND PUSH Mc TO SEE IF ENGINE IS SEIZED. .
JUMPER CABLE JUMP THE MC BATTER TO A CAR BATTERY.?
CHARGE YOUR BATTERY FOR 4 HOURS OFF A 10AMP CHARGER? LETTING LEAD/ACID BATTERY JUST SIT ASKS FOR Sulfation DAMAGE occurs when a battery is deprived of a full charge, I KEPT ALL MY MC (HAD 5 OR MORE) ON FLOAT CHARGE AND NEVER DID THEY FAIL. FULL TIME PARKED UNUSED.
FUSES GOOD
BATTERY GOOD
STARTER RELAY GOOD
STARTER GOOD
ENGINE NOT SIEZED.
ALSO MANY MOTORCYCLES: this era up.
ALL HAVE NEUTRAL SWITCH STARTER CUT OUT.
SOME HAVE KICK STAND CUT OUT.
SOME HAVE HANDLE BAR DEAD MAN SWITCH LEVERS SET WRONG,
OR CLUTCH SWITCH SAME. CUT OUT.
OR BAD KEY SWITCH OR ANY WIRE TO ANY IF THE ABOVE BAD.
my huge BMW had all that, even in 1977
OR DID YOU MEAN Honda ST 1100 Pan European????????
IS IT SO HARD TO SAY MAKERS NAME FIRST?
And not put the ST on the wrong end,if true?
but but but !
but is same answer, all motors have the same things , for cranking, (well not my nasty Yamaha' Vargo of old)
starter cutouts on MC are vast, vary by year.
and free manuals for me to read to you never free
pan head or pan European, I fail.
buy the service manual if serious DYI.
see all cutouts and test them all if engine not seized.
use a voltmeter tool , gue$$ing is no fun.
check with the local laws is your area as to collections-- depending on amount and or arrangement you can confer with an ada from a civil court or supreme court as to what rights or laws are as to collecting a debt and what the restrictions are in doing so
If you are watching an hd channe, the aspect ratio on the set is changing by itself. Some sets allow you change it. Look for the aspect ratio in the menu.
To answer your question: The "boarders" you see are due to the video being displayed being at a smaller vdeio display setting than the TV can handle.
Example: If your video is 640x480 because it is coming from a Wii or DVD Player device, and your TV can handle a display of 1280×720; then you will see boarders around the left and right edges.
Solution: Search the display menu of your TV and see if it has "Automatic", "Panoramic", "Wide", "Zoom", or "Fit to Screen" options. This will eliminate the side boarders, but may also cut some of the image off of the top and bottom of the display as well.
I'm a shop owner , import cars repair.
I have about 50/50 European and Japanese cars in my customers database , 70% of money coming from European cars and they more offten here.
On Japanese it's almost only scheduled services , and ware and tear , German cars are braking down.
Audi and VW have more problem then MB and BMW.
Hope it helps.
