SOURCE: Philips 27PT9007D/17 27" front panel
Hello
Just unlock the TV by using overriding the lock code procedure. After that, just reinsert the code. To overide the code and to unlock the TV; just do the following.
Philips sets use a four digit code to control the v-chip. The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
[1] From the PARENTAL CONTROL menu, press the up or down arrow to highlight
Lock Fr. Panel.
[2] Press the right or left arrow to turn on (box has check mark) or off (box doesn't
have check mark) front panel lock.
OK.
