SOURCE: whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
SOURCE: Cannot locate lint trap to fit my wsm2420 sazww
In the Kenmore equivalent, the lint trap is on the back wall of the interior of the dryer. If GE is the same then you'll see two vents at the back inside, one is the intake (where hot air enters), the other is the outtake, which contains a lint trap. You might have mistaken both for nonremovable vents. But one of them is removable. It should have finger holes or something to grab. Just pull it and it will pop out without difficulty. It's probably a two-piece unit (a grate on the dryer side and a screen on the exhaust side, with a space in between for collecting lint), which snaps or slips apart easily, then you can clear the lint, and then snap or slip it back together and just push it back in place in the dryer.
SOURCE: hnwl 3136 lint in wash, how to clean
For general advice on cleaning a washer lint filter, try eHow: cleaning a washer lint filter.
Item #2986 (OEM Part)
$10.70
Thermal fuse. If the dryer overheats, this device stops the flow of electricity to the heat source and/or the entire dryer. It is located on the blower housing and cannot be reset. The most common cause for overheating is a vent tube clogged with lint, a birds nest or other debris.
Manufacturer Number 3392519
More
In Stock
Quantity:
http://www.repairclinic.com/PartDetail/Thermal-Fuse/3392519/2986#repairHelpVideoTabs
