Televison & Video Logo
Amanda Posted on Jan 15, 2019
I need to factory reset my TV and I don't have the remote and front panel is locked. What do I do?
  • timoboon2 Jan 16, 2019
    Hi Amanda , Please give the brand and model number of the TV.
  • b1jqxk44
    b1jqxk44 Jan 16, 2019
    Amanda, unplug it for about two hours. That should blank the memory of the TV. When you plug it back in it should go to the setup screen, and the front panel will be unlocked. If it does not go to the setup screen, unplug it for even longer.
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Mar 17, 2007
SOURCE: front panel locked and remote don't work
Are you sure there is not a problem with the TV set? The set will need to be on to unlock the front panel. Bypassing the V-Chip Lock on most Mitsubishi sets use a four-digit passcode that is required to view a V-Chip locked program, view the locked TV, cancel the lock, or enter the V-Chip lock menus. If you don't have the passcode, it is easy to bypass. This is neccessary if you forgot the code, purchased the set used, or if you simply don't feel like searching through your files to find it. To bypass the V-chip: You can view the locked shows by pressing the number 9 and QV buttons on the remote at the same time, whenever your passcode is requested. This process temporarily unlocks the TV. To reset the code: When you use the button combination 9 and QV while entering the V-Chip Lock menu, this process deletes your old passcode and prompts you to enter a new passcode. Good Luck
Anonymous
  • Posted on Jan 03, 2008
SOURCE: DMR-ES30V remote and DVD panel buttons not responding
I assume you have fixed this by now, but if not, call panasonic's help line (number is in your owner's manual). They will walk you through the complete reset process (maybe 5 minutes). you will have to re-program everything the same as you did when it first came out of the box, but that doesn't take too long. Also, first try taking the batteries out of the remote. Make sure they are still good. Wait 60 seconds or longer, then replace batteries.
lexon
  • Posted on Feb 28, 2008
please reply me
Anonymous
  • 1153 Answers
  • Posted on Mar 22, 2008
To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds
Anonymous
  • Posted on Dec 20, 2008
SOURCE: Recieving "Locked" display message but don't know how to clear it. No reset switch or panel lock button
I have the manual and it is called "child lock" go figure it stumps us adults. Anyway...holding the power button down for approx. 8 seconds can toggle this feature on / off
TV Sharp LC-40LE830U. My front panel ys disabled and my remote control don't work. I can power on/off only. How can I enable my front panel without use remote control? or reset factory settings?
If both your front panel and remote control are disabled, the best option would be to perform a factory reset to restore the TV to its original settings.
To reset the Sharp LC-40LE830U to factory settings:
  1. Unplug the TV from the power outlet and wait for at least 60 seconds.
  2. Press and hold the power button on the TV for 5 seconds while the TV is still unplugged.
  3. Plug the TV back in and turn it on using the power button on the TV itself.
  4. Once the TV is turned on, press and hold the "input" and "volume down" buttons on the TV simultaneously for 5 seconds.
  5. The TV will then enter the service mode menu.
  6. Press the "menu" button on the remote control to navigate through the menu and select "option."
  7. Select "factory reset" from the options menu and follow the on-screen instructions to complete the reset.
Note: The factory reset will erase all custom settings, including parental controls, picture, and audio settings.
1helpful
3answers
How do I reset my tv without remote control?
Without the remote control, you can not do a factory reset; Can only of the hard reset. There are two methods to reset TVs. The first is simple to do; Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it to reset system [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the website linked here. Pull up older posts. Http://electronicshelponline.blogspot.com/
Service entry mode, adjust and exit procedure to many popular brand are given Beheerder TVs. Never forget to exit the service mode, after all adjustments Have Been done.
Tv reset menu
On the front there should be a panel you can open if you dont have a remote. On that panel there should be a reset button.Just press it while the tv is on.
1helpful
Locked out front control panel while in menu. Now I can't unlock front control panel and I don't have original remote control or owners Manual. Help me please. The front panel is all I use for DVD pla
Hi there, if you know what model it is you can do a google search for the owners manual. There should be a sequence of buttons you can push or hold to reset to factory/default settings.
1helpful
Cannot get AV Mode
There is a TV/VIDEO button on frond panel of the tv. When you press each time this button then you will able to access different video inputs. if the button is inactive the probably the micro switch for TV/VIDEO button may be faulty. also check the same with the remote. If its doesn't help then try to reset the tv to factory default setting. For that you need the remote. Keep in mind that when you reset the tv to factory default setting all the memorized parameters will erased(like channel memory, personal preference setting etc ). For reseting the tv to factory default do the following
1.Turn on the TV.
2.While holding down the RESET button on the
remote control, press the POWER button on the TV front panel.
The TV will turn itself off, then back on again. Release the
RESET button
Ajin
4helpful
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
1helpful
Can you turn off the FPA lock without an original remote? If so, how?
If you remember your pass word then you can use any remote that operates the TV to reset the menu selection. However if you don't remember the password, then sorry, the original remote must be used.
Below is the procedure to set up the menu for front panel lock, unlock and the password reset.
Front Panel
Selecting this option lets you lock (disable) or unlock (enable) the TV's front
panel buttons. The remote still tunes to any channel so remember to remove
access to any remote that can operate the television.
1. Choose Parental Control from the Main Menue and press the OK button.
2. Enter your passworcd.
3. Press the down arrow to highlight Front Panel.
4. Press the right or left arrow button to choose unlock (_) or lock (_).
I don't remember my password and I want to unlock the TV
If you forget your password, you must reset it. Make sure the TV is of. Press VOL- (down) on the TV's front panel and then
CLEAR on the remote for approxhnately 5 seconds. The TV turns on. Enter a new password next time you access
the PARENATAL CONTROL menu or the TIME_menu.
Subtitles are coming turned on,and I can't get turn them off what should I do
Hello
Your TV has mistuned with improper remote entry. Set it reset to factory settings. To set it to factory settings, do the following.
Using the "POWER button on the front panel or remote control, cycle
the power off and back on again. When the front panel LED displays
"boot", press these buttons in a sequence: "UP, DOWN, BACKWARD ARROW" and
" MENU-SELECT". The Receiver will be reset as the default status
automatically.
Use the default password "0000" to access the Lock menu and set a
new password.
Be sure to repeat your channel Auto Scan before using the receiver.
ok
2helpful
Front panel locked and remote don't work
2answers
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
