These came with my vehicle which I no longer own. Can they be used for other electronic devices or computers with Bluetooth for listening to music etc ?
SOURCE: Windows Vista wont connect to these headphones
Try going to control panel->sounds->make the hands free audio the default.
SOURCE: my speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
SOURCE: Windows 7 and Dell BH200 Bluetooth Headphones
You have to set bluetooth as default audio device. For doing this, go to >Contro Panel> Sound and Audio Devices>Audio(Tab) and in Default Device choose bluetooth device.
In my case, I had problem when i installed SP3 on XP. I changed my bluetooth driver to "Toshiba Bluetooth Stack V6.00.10" and it worked for me.
SOURCE: When I go to listen to my mp4, it says
I started to have the same problem today and was also getting a "Library Error Encountered...." message. I was able to resolve it by Formatting my player. I lost all my data and settings but now I can put music on it again. To format your player go to the Home menu-Settings-Common Settings-Format
SOURCE: yba-10 search not found for bluetooth device.
I am having the same problem. My Yamaha RX-V665 has the yba-10 bluetooth unit. My computer pairs ok but I get no sound to the receiver. If I play my music thru windows media player on my computer it works great. I really want to use ITunes??? Anyone have any ideas to help???
