Nishiki Adult Alamosa Mountain Bike 2013 Logo
Debi Ryan Posted on Jan 15, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I release air pressure on tire of nishiki so I can pump tire
Donald Ayers-Marsh
Level 3:
  • Nishiki Master 1,389 Answers
  • Posted on Jan 15, 2019
Donald Ayers-Marsh
Nishiki Master
Level 3:
Answers
1389
Questions
0
Helped
559538
Points
6679
You don't need to release air pressure to pump up the tire. If you have tubes with "presta" valve stems you need to unscrew the knurled nut on the end of the stem before inflating the tire. Presta stems also require the correct type of fitting on the end of the pump hose.
Tire maintenance
Check your tire air pressure at least once a week and before long trips. Be sure to use an accurate pressure gauge. -Check your air pressure when the tires are "cold." The tires are "cold" when your motorcycle has been ridden less than a mile at moderate speed or after being stopped for three or more hours. -If you must add air when your tires are hot, add four pounds per square inch (4 psi)(28 kPa) above the recommended cold inflation pressure. Recheck the inflation pressure when the tire is cold. -Never release air from a hot tire in order to reach the recommended cold tire pressure. -Normal riding causes tires to run hotter and inflation pressure to increase. If you release air when your tires are hot, you may dangerously under inflate your tires. -If your tires lose more than two pounds per square inch (2 psi)(14 kPa) per month, the tire, the valve, or wheel may be damaged. Consult your local dealer for an inspection. -Use valve caps to keep valve cores clean, clear of debris and to help guard against air leakage.
Tire maintenance
Check your tire air pressure at least once a week and before long trips. Be sure to use an accurate pressure gauge. -Check your air pressure when the tires are cold. The tires are cold when your motorcycle has been ridden less than a mile at moderate speed or after being stopped for three or more hours. -If you must add air when your tires are hot, add four pounds per square inch (4 psi)(28 kPa) above the recommended cold inflation pressure. Recheck the inflation pressure when the tire is cold. -Never release air from a hot tire in order to reach the recommended cold tire pressure. -Normal riding causes tires to run hotter and inflation pressure to increase. If you release air when your tires are hot, you may dangerously under inflate your tires. -If your tires lose more than two pounds per square inch (2 psi)(14 kPa) per month, the tire, the valve, or wheel may be damaged. Consult your local dealer for an inspection. -Use valve caps to keep valve cores clean, clear of debris and to help guard against air leakage.
Tire maintenance
1helpful
Tire maintenance
Tire maintenance
Tire maintenance
Tire maintenance
Tire maintenance
Tire maintenance
2answers
Tire maintenance
Top Nishiki Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Nishiki Cycling Expert? Answer questions, earn points and help others
