The 40 signifies the same power output, pick the one that's best for your individual needs regardless of the title as both have the same amount of power!
Let me know if this is helpful by clicking "Helpful", feel free to leave very brief review or follow me, I deal with automotive/mechanical/technical and other subjects relevant to daily life. Thanks and have a great day!
SOURCE: i have a minn kota deckhand 35 that wont wind up.
Solution- Take the cover off the Deckhand 35 by Minn Kota. Inside is a motor drive. Remove the cover plate held in place with 4 screws. inside are nylon gears, most likely broken. The gears can be replaced with a Minn-Kota Deckhand Gear Repair Kit.
I found mine on the web at Northland Marine.com it's about $24.00 for the kit, plus shipping.
Good Luck!
SOURCE: Speedstream router - password retrieval
Try using the following default user name & password:
Username : admin
Password : hagpolm1
SOURCE: anchor winch
There is a great chance the clutch has frozen due to corrosion.It need to be pulled apart at the clutch.Its not a big job and quiet easy.The plates freeze together and need to be "cracked" apart.I hope this helps
SOURCE: Minn Kota Deckhand stripped gears
Hello!
Here is a schematic for your Deckhand:
DH40
The install of the large plastic gear is fairly easy if you are somewhat mechanically inclined (you must be if you posted the question ;)
Give it a go, last one I did took about 20 mins.
Mike
