SOURCE: Konica Minolta C450- error code c-2251
It's been a while since you posted that but you may just need to slide it back out and shake it back and forth (long ways) a few times. We had the same problem and the konica minolta tech told us to do that. It worked. DO NOT turn it upside down though.
SOURCE: Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
SOURCE: Minolta Magicolor 3300 Imaging unit
I had the same problem. Check out page 3-308 of this document.
Take off the side cover and re-engage the gear. Should solve the problem.
ftp://ftp.qms.com/pub/cta/out_going/other/diagcd/mc3300sm.pdf
SOURCE: imaging unit has stopped working
go to tech rep mode> turn off the copier and while pressing the utility button turn on the copier and hold keep on pressing till 6 second. the menu will appear and choose to reset the life of the consumable supplies.
SOURCE: Konica Minolta C353 has a C4551 error, how do I fix it?
try replacing the imaging unit with a new one not a reset imaging unit
