SOURCE: Temp
I've had my Samsung RS267 LASH side by side for almost 2 years now and the coils froze recently. The temperatures displayed - relating to the refirgerator side - bounce around when the coils freeze. My freezer thank goodness is still working properly. The repairman indicated that the heating element for the refrigerator coils was bad. Unfortunately he had to order the whole unit (coils, heating element, etc.) since he couldn't replace just the one part. Samsung takes their time sending the parts - we've been waiting for 10 days now. The Samsung warranty covers the compressor, evaporator, condensor, drier and connecting tube for 5 years parts and labor so we should becovered. You might be covered as well - depending on when you purchased your refrigerator. I did purchase a separate extended warranty from Lowes when I bought the refrigerator and I'm glad I did. My extended warranty included $250 in food spoilage covering our food loss due to the breakdown. Hope this helps......
SOURCE: I turn on bbq it lights, put temp settig to high
1 Uniflame 40,000 BTU 3-Burner Gas assembly video. where do i find the video
SOURCE: Viking 6440, sticks in reverse. Hair dryer on high
You need to purchase a de-greaser spray to clean out the old grease. Im sorry but Im not an expert at this type of machine, but most of the inner workings are similar to all brands. You need to remove the top to expose the crankshaft device that is inside, and spray with a de-greaser. If you know the area where it sticks try that area first. A common de greaser is actually WD40. It lubricates and de greases, you could try this, if available in your area. You may have to use a lithium based grease for that machine I cannot say for certain. I do however have a link to the Husqvarna help site if that will help.. http://www.husqvarnaviking.com/us/2821_3079.htm
SOURCE: AC not cooling
first off you should have a four ton unit. what is your super heat? is it pulling attic or outside air?
