SOURCE: Sharp Blu-Ray model BD-HP20X locked to region 4 how to unlock ?
Well I Checked my data resources and saw that there are no hacks or tricks for Sharp yet... the only thing you can try doing now is to ask your Dealership if they can unlock the regions for you. I've searched everywhere but couldn't find anything for newer models like HDDVD or Blu-Ray players.
Sorry T_T But let's hope someone might be able to help as well..
SOURCE: player not responding
Please remove any disc from the unit and try resetting it by removing the disc and placing the unit in stop mode. If you now press and hold the fast forward skip button on the front of the main unit for over 10 seconds. To confirm the reset, when you power the unit off and on the language selection screen should dispaly.
SOURCE: need firmware for bd-p3600 blue ray disc player
http://www.blu-ray.com/firmware/firmware.php?id=49
Here is the link for the new firmware.
Good luck :)
SOURCE: want to update my sharp blue ray disk player bd-hp21u
To obtain the software update file, please call 1-800-BE-SHARP (23-74277). Save the update file into a USB drive.
with the update file into the BD
STORAGE/SERVICE terminal on
rear of this player.
MENU screen.
“SETTINGS”, then press ENTER.
UPDATE”, then ENTER.
in the USB memory device.
“Checking” blinks.
and the version of the update file on the
USB memory device are displayed. To
update this player software with update
file, select “YES”, and press ENTER.
properly installed or the correct update
file cannot be found on the USB
memory device, an error message is
displayed.Check the file on the USB memory
device, and then reinsert the USB
memory device correctly.
while until the update screen can be
displayed. Please wait for the update
screen to appear. Do not unplug the AC
cord
updated, a screen is displayed
indicating that the update process is
completed.If the update has failed, check the file
in the USB device and try Software
Update again.
SOURCE: Dynex router blocks connection of Samsung BD-P1600 Blu-Ray to Net
I'm not familiar with that particular router, but all of them are about the same. You can go in and edit firewall settings to allow a particular IP address to have access. Don't disable the firewall completely, just set it to allow that I.P address to have full access.
