Cameras Logo
P
Phyllis Galsky Posted on Jan 15, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you remove the CBD bulb in a Bell and Howell 977q slide projector?
ADMIN Andrew
Level 3:
Top Expert:
  • Cameras Master 66,931 Answers
  • Posted on Jul 17, 2021
ADMIN Andrew
Cameras Master
Level 3:
Top Expert:
Answers
66931
Questions
Helped
5081307
Points
379583
5 Related Answers
A
Anonymous
  • Posted on Aug 19, 2008
SOURCE: Downloadable instruction manual for Bell Howell 456 super 8 mm dual movie projector
Anonymous
  • Posted on Mar 17, 2009
SOURCE: How do I thread the film through an 8mm B&H Projector
http://www.folkstreams.net/vafp/stream.php?id=97
It's about four and a half minutes long, and shows how to clean the various components that need cleaning beforehand as well as how to thread the projector.
However, I wish you good bloody luck on finding a bulb, if you don't have one that still works. From the look of the unit, it uses a DAR bulb, which was delisted (read: went out of production) thirty years ago. You can sometimes find new old-stock (NOS) DAR bulbs on eBay, but expect to pay $30 to $35 apiece plus shipping for them.
Sam
Anonymous
  • Posted on Jan 27, 2010
SOURCE: I have an old Bell & Howell projector and I
These guys obviously have something to sell. PLEASE DON'T THROW YOUR MOVIE PROJECTORS AWAY. DVD-R has a useful life of about 5 years at best.
To answer the question posted: As the bulb ages, the extreme heat causes a bulge in the glass and that's why the bulb won't slide down. The only option is to tap the top of the bulb with a screwdriver (or similar instrument) and shatter it--then unscrew the housing and let the mess fall out. Be sure to protect yourself from shards! Once you clean up the mess you can install a new bulb (DAR, I believe).
Once you see the rich gradations color of real film (even 50 year old film), you'll be hooked!
Anonymous
  • 25 Answers
  • Posted on May 08, 2010
SOURCE: My Bell & Howell cube slide projector has a
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=360183793446
Bell & Howell Cube Slide Projector Gear, New Item condition: New Quantity: More than 10 available Price: US $15.00 Approximately C $15.54 Buy It NowBuy It Now
This is the gear that goes bad on Bell and Howell cube type slide projectors. If you have one of these projectors you can pretty much expect the gear in your machine to go bad. The original gears were made out of an inferior material that was too soft. New old stock gears would be made of the same material and although they have never been used they most likely will fail right away since they are made of the same inferior materal. They were made soft to reduce the mechanical noise when the gear runs. This was told to me by the person who designed them at Bell & Howell. These new replacement gears are made out of Delrin, an excellent material for gears. Delrin is sometimes used to make gears that are normally made of metal. Don’t miss your opportunity to finally fix that old projector or get a spare gear for your working machine while they are available.
Detailed installation instructions will be included with every gear.
Anonymous
  • Posted on Sep 04, 2010
SOURCE: I have a Bell & Howell slide cube projector
I occassionaly experience the same problem. I don't know why it occurs, however; here's what I do to get the projector moving again: 1) Face the right side of the projector wherein the lens will be pointing to your right. on the middle top of the projector edge closest to you you will see a top access tab. 2) Move and hold the tab to the left and lift open the top of the projector. 3) On the edge of the rotating tray at about the 5:00 position (my guess as I'm not at the projector now) you will slot in the circular plate aligned with another slot on the fixed casing. Inside this sloted area there is a metal pieve that spans the slot across the two surfaces. 3) Take a screw driver and giggle this metal peice, pressing dow and releasing, and / or in and out, while pressing the slide advance advance forward and back. I found no ryhme or reason to this or that it readilly works after so many jiggles, however; it alsways does usually after anywherefrom a few seconds to a minute or two. This isn't a fix but a temporary workaround. I'm in the process of sulling my thousands of slide to be digitized, after which I will no longer need this wonderful legacy machine. Hope this helps. Regards,
[email protected]
How do I replace the bulb in a Belle Howell Model 977Q
1) look up bulb code in manual.
2) buy new bulb
3) switch off power
4) remove old bulb
5) insert new bulb
Sep 30, 2019 • Cameras
Bell & Howell slide projector 454
go on line to bell & howell site and down load service manual or operators manual.
Need bulb DFC for Bell & Howell Model 256
what kind of lamp do I need for a Bell & Howell projector model 256?
I bought this projector but doesn't come with the bulb.
2helpful
2answers
May 20, 2008 • Photography
Change a bulb
Hi Janet,
Put on rubber gloves.
Hold bulb and push down and turn counter clockwise to remove bulb.
Maybe hard to remove, try spraying WD-40 first. MAKE SURE AC CORD(power cord) is disconnected. Wait a few hours and try to remove the bulb.
[email protected]
Jan 12, 2008 • Cameras
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
