Check reset on bottom right
SOURCE: sony wegakv36hs500 fd trinitron
The flashing light normaly indicates that the power supply section is in the protect mode, or has failed, and or there is a failure in the scan amplifier section, and or there is a short most likely there may be a short. There are many things that can cause this type of fault. You will have to take the set to a Sony service center or the equivement to have your set properly serviced.
Jerry G.
SOURCE: HP md5020n does not have picture
UNPLUG IT AND IFF YOU CAN TAKE THE BACK OFF ,,AND CAREFULLY LOOK ALL IN THERE FOR A FUSE ,,SEE IF ITS BLOWN,,
SOURCE: Sony Trinitron TV
read the answer on this page really helpfull
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Sony-Trinitron-KV-32V42.htm
SOURCE: TV blinks red twice
Get into this blog for details. Blinking codes and faults are described. Number of blinking denotes the fault. Just get into the blog for details.
blog address is
electronicshelponline(.)blogspot(.)com
blog name Electro-Help
Type in this blog address [without any brackets] into the address bar of your browser and press Enter
You can also Google it.
514 398 065
Four digit code is:
0125
1* Turn your TV and SkyHD box on and press tv on your remote control.
2* Hold down select and the red button together until the red light on your remote
control blinks twice (this is after about two seconds).
3* Press tv again.
4* Key in your TV's brand code. The light on your remote control blinks twice.
5* Press standby on your remote control.
If your TV switches off, press select.
The light on your remote control should blink twice.
If your TV does not switch off, press tv, then press standby.
Repeat the sequence of pressing tv then standby until the TV switches off,
then press select.
If the light blinks three times, your remote control has checked all the possible
settings for the code you used. Check you have the right code and start again
at step 1.
*6 Turn your TV back on and press the tv guide button on your remote control.
The TV Guide screen appears, meaning the remote control settings have
been reset.
