Food Mixers Logo
Celtic Dog Posted on Jan 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kitchen aid mixer modelksm90wh I broke the black knob on the set lock lever,,, is this a hard fix
CJ Rock
Level 3:
  • Master 4,429 Answers
  • Posted on Jan 15, 2019
CJ Rock
Master
Level 3:
Answers
4429
Questions
0
Helped
1645406
Points
15024
It involves unit disassembly.You'll have to determine easy/hard given your skill set.
Search on "kitchenaid tilt lever replacement" for video.
5 Related Answers
A
Anonymous
  • Posted on Jan 19, 2007
SOURCE: Kitchen Aid Classic Mixer
I have this problem too -it is rather common if you search the web. There was a suggestion posted on this site about what to do. See http://www.fixya.com/support/t125253-mixer_leaking_oil I have also read about other people taking it to a Kitchen Aid repair place where they repacked the grease for about $45. I took mine apart and there is gobs of grease around the gears. Right now I am still trying to figure out what to do. I am going to have my father look at it to see what he thinks since he is good with motors. The Kitchen Aid web site says that the grease is FDA approved, so at least it's not going to kill you if a little gets in your food. Their suggestion is to take it out and run it for about 5 minutes at least once a week. They say it leaks if it is not used often enough. That logic doesn't make much sense to me, but you could try it. Mine seems to leak more when I run it because the grease heats up and liquifies more. I hope that helps. I'll let you know what happens with mine, once it's fixed. Lisa
Anonymous
  • 849 Answers
  • Posted on Oct 31, 2008
SOURCE: Kitchen Aid Mixer
you should replace that part with new one
Anonymous
  • 145 Answers
  • Posted on Jul 08, 2009
SOURCE: The head to my kitchen aid mixer bounces up when kneading dough
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Anonymous
  • 235 Answers
  • Posted on Dec 01, 2009
SOURCE: leaking oil from kitchen aid mixer ksm150ps
Hi, BRIANMICHELL ? How much oil are we talking about, and over what period? How old is your machine? Your KA mixer?s internal gears are factory packed with enough grease to last a lifetime, whatever that means. Depending on the age of your mixer, where it was stored (warm temps possibly?) and how long it's been idle and/or how heavily it?s been used; these factors all will eventually cause the lubricant grease to separate into its base oil from its additives, with the resultant oil seeping from openings beyond the gasket down the agitator shaft. Gravity can be very insidious. The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, try KSM150PS, and select one of the files listed under Parts List (check to see it this matches your mixer model). Turn to pages 6 & 7, titled ?Case, Gearing and Planetary Unit?, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts. For starters you may want to order parts #15, transmission gasket, and # 16, O-ring, along with some food-grade grease. Also, while you?re inside the guts of your mixer you can check for any other unseemly wear and tear on the gears, etc. It can be messy but gratifying. As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping. Finally, here's a link to an excellent site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html Good luck and have fun. I hope this helps. Howard, Burke, VA If this solution has helped you, please rate it, thanks! - hslincoln
Anonymous
  • 235 Answers
  • Posted on Dec 07, 2009
SOURCE: kitchen aid gear- where the beaters are attached -
Hi BEV, By the symptoms you are describing, it appears that your planetary/agitator shaft (where you attach the beaters) assembly is dropping from the mixer head, is that correct? When you replace the planetary and lift your bowl up into a ‘locked’ position, the planetary is being held in place by the beater resting on the bottom of your mixing bowl and ‘works’ for the time being. However, you don’t want operate your mixer that way for very long.
I suspect what caused the planetary/agitator shaft to drop from the mixer head is that one of the pins used to secure the planetary/agitator shaft assembly to the mixer head has failed (sheared) so now there is nothing holding the planetary/agitator to the mixer head. The good news is that this is fixable.
The inspection and troubleshooting of your mixer’s transmission is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. If you are lacking one, you can download it from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM50PS. Unfortunately, entering your exact model number yields many Owners manual and no Parts Manuals, so I would use the following, KSM500, and select the last file under Parts List (16) KSM500WH0.pdf (857.41 KB). Verify your mixer matches the mixer in the illustrations. Turn to pages 4 & 5, titled ‘Case, Gearing & Planetary Unit, for the disassembly, troubleshooting, and reassembly of your mixer, along with a listing of all the parts. Make sure you inspect
Locate Illust. No. 14, Groove Pin, Part # 9795443. This pin retains the planetary/agitator shaft to the mixer head, and I suspect this is the pin that has failed and needs to be replaced. Getting to it will require the disassembly of the whole transmission. This will be messy as you will need to remove all the grease from the gears and center shaft.
While your mixer’s apart you should check for any other unseemly wear and tear on the gears, etc. You may find more things that need replacement than just the groove pin.
Besides needing a replacement pin and grease, you might consider replacing the gasket, too. I recommend using a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call).
Here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Here’s a link to an excellent site for disassembling/fixing your KA Mixer. Although it’s a different model, the principles are the same: http://www.neilcrockett.com/mixer.htm and another link to a site that details the disassembly and replacement of mixer’s grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.htmltl
If you feel troubleshooting and repairing is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping.
If this solution has been helpful to you, please rate it, thanks! – hslincoln
1helpful
My kitchen Aid mixer lever will not move...help
Which lever? Speed control or tilt head lock?
Jun 24, 2017 • Food Mixers
When itry to make bread dough in the mixer, the bowl locking mechanism doesnt work properly and the bowl moves and top of mixer jumps around how can i fix this
You need to make sure that the hinge pin is tight, turn machine completely upside down and tighten the slotted screw up inside the pedestal. If that doesn't fix it you will need to check that the locking lever is properly engaging in the slot. You may need to "SLIGHTLY" file the slot in the pedestal that the lever engages into. If you go mad with the file you could wreck the slot.
Needing the black plastic knob on the speed control lever for my Kitchenaid Professional 6 model #KP2671XOB
It is correct that the knob is not separate from the shaft it is attached to. If they are obsolete then hop into your local Kitchen Aid retailer and see if your missing knob looks same or similar to a current model, if so order for a current model, lever the knob off the shaft (carefully) and tap it onto your bare lever. I use a soft faced hammer for this. These folks here should be able to help if you are USA based. http://www.searspartsdirect.com/
Kitchen aid mixer power lever won't move
Hiya,
I am sorry to hear you are having problems with your lever.
I have added a link below for our help page on replacing your speed lever:
https://www.youtube.com/watch?v=y97KT98vpJ0
I have also added a link below if you wish to purchase a new speed lever:
9709276 KitchenAid Tilt Head Stand Mixer Part (also 5qt bowl lift) Speed Lever Black https://secure.kaparts.co.uk/sku/9709276
I hope this helps you :)
Kitchen aid artisan mixer is loose and shaking
This could be the pivot rod between the head and the column being loose and out of place. Or it could be the hook activated by the lock lever not engaging properly. See the following Service Manual:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
2helpful
Who repairs kitchen aid mixers
Call the Kitchen Aid small appliance warranty office and they will tell you where the authorized repair person is that is close to you.
1helpful
The speed lever on my KSM 90 won't lock in the off position.
Do you have a manual? You can download one from Kitchen Aid, small appliances. There should be a schematic and how to that will help.
Kitchen aid artisan speed control stuck
Hiya,
Sorry you are experiencing an issue with your appliance. We have some help videos to assist you with resolving this issue. Please see one of the links below for your perusal.
https://www.kaparts.co.uk/Help/KitchenAidHelp/KitchenAidMixerHelp/Howtoreplacethespeedlever/tabid/643/Default.aspx
To purchase new speed lever, please see the below link:
2answers
Kitchenaid mixer
Try replacing the moter brushes,if not its probably ether wiring or in the switch board.
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
